Go to Post The only way to make a noticeable shift in OUR culture is if there are a lot of small shifts. - JVN [more]
Unread 27-01-2009, 07:53
Re: Reading battery power on Driver station.
Dig,
The Crio and drivers station must have compatible code running. If you (or the software team) updated the Crio and did not update the DS you will have problems. Please be aware there is a specific method for updating code especially on the DS. Do not interupt the operation when flashing the DS See p6 of the control system manual. This operation will also change your team ID so that will need to be reset after each software upgrade.
Dead Driver Station? tdeprince FRC Control System 3 12-02-2009 12:14
Driver Station Update ExarKun666 FRC Control System 8 15-01-2009 10:39
Driver Station Login Mr-Shutter FRC Control System 2 12-01-2009 23:36
2nd Driver Station bcharbonneau General Forum 2 09-01-2009 14:19
Reading battery voltage in software RbtGal1351 Programming 17 21-10-2007 13:07
