Go to Post Umm, guys, the stacking game was last year. Toss the Genia is much more appropriate for Aim High. - Greg Marra [more]
Unread 26-01-2009, 22:07
Digmaster Digmaster is offline
AKA: Thomas Luppi
FRC #2827 (Srown City Robotics)
Digmaster is an unknown quantity at this point
Reading battery power on Driver station.
Anyone mind telling me how to change the v00.00 to the actual battery voltage?
Unread 26-01-2009, 22:16
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
Re: Reading battery power on Driver station.
Do you have the Analog Breakout hooked up on slot 1? The battery voltage is measured on channel 8.
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 26-01-2009, 22:20
AKA: Thomas Luppi
Is that the object in the cRIO that says analog in?
If so, please give us exactly what to do. We're a new team, and everyone is gone but the programmers. I'm the only electrical left, and I feel like doing something to show others tomorrow.
Unread 26-01-2009, 22:36
AKA: Thomas Luppi
I placed a jumper on the thing that says Analog In in slot 8 and restarted. The driver station now says no code. The programmers are too busy changing the code's comments and stuff so it looks like a drunk guy wrote it, so should it say anything other then no code?
Unread 26-01-2009, 22:46
MattD's Avatar
The first slot on the cRIO should have an NI 9201 Analog Input module plugged in. The Kit of Parts includes two Analog Breakouts, as described in section 3.4 of the FRC Control System Component Data Sheets. That section should contain all of the information you need to install the Analog Breakout and get things working.
Make sure to note this detail:
How do I measure the battery voltage using the Analog Breakout?
• Use a shunt (jumper) to connect the outer two pins of the “AI8 Select” connector
• Battery voltage is reduced to ~40% of its actual value by a 680/1k voltage divider and
filtered by a 0.1uF capacitor.
Edit:
No Code seems to indicate that there is no user program running on the cRIO. There's probably nothing deployed, so your program isn't running on startup. In WindRiver you can deploy your program using the FIRST->Deploy menu, but I'm not sure how to do this in LabView.
If you run/debug your program in RAM, you should see the battery voltage on the Driver Station, provided everything is set up correctly.
Unread 27-01-2009, 07:53
Dig,
The Crio and drivers station must have compatible code running. If you (or the software team) updated the Crio and did not update the DS you will have problems. Please be aware there is a specific method for updating code especially on the DS. Do not interupt the operation when flashing the DS See p6 of the control system manual. This operation will also change your team ID so that will need to be reset after each software upgrade.
Unread 31-01-2009, 13:20
BrandonD-1528's Avatar
BrandonD-1528 BrandonD-1528 is offline
AKA: Brandon Dusseau
FRC #1528 (Monroe Trojan Robotics)
BrandonD-1528 is a jewel in the roughBrandonD-1528 is a jewel in the roughBrandonD-1528 is a jewel in the roughBrandonD-1528 is a jewel in the rough
The jumper goes on channel 8 but which two prongs. Sig and + or + and - ?
Brandon Dusseau (website)
Monroe Trojan Robotics mentor
Software Engineer
Michigan Tech alumnus
Unread 31-01-2009, 19:59
Originally Posted by <R64>
A National Instruments 9201 module must be installed in slot 1 of the cRIO Mobile Device Controller. An analog breakout must be connected to this module. A jumper must be installed on the “Battery Voltage” and “Power” pins on the analog breakout. The analog breakout must be powered from the Power Distribution Panel. Please refer to Section 3.4 of the “FRC Control System Component Data Sheets” for information on these connections.
Chapter 3 Control System Data Sheets can be found at http://www.usfirst.org/frccontrolsystem, under the Control System Manual heading.
Unread 31-01-2009, 20:09
Please read the manual. You are at risk of damaging components.
Dead Driver Station? tdeprince FRC Control System 3 12-02-2009 12:14
Driver Station Update ExarKun666 FRC Control System 8 15-01-2009 10:39
Driver Station Login Mr-Shutter FRC Control System 2 12-01-2009 23:36
2nd Driver Station bcharbonneau General Forum 2 09-01-2009 14:19
Reading battery voltage in software RbtGal1351 Programming 17 21-10-2007 13:07
