Go to Post when I was a ball setter at PARC one year (6th grade?). As soon as I saw what High school students could do with thier own two hands and how they mingled with industry, I knew, at that moment, it was for me. - henryBsick [more]
View Poll Results: Are you going to use a fan/ propeller on your robot for thrust?
Yes, fans for everyone 11 8.73%
No 107 84.92%
Maybe 8 6.35%
Voters: 126. You may not vote on this poll
Unread 24-01-2009, 20:39
Greg Peshek Greg Peshek is offline
FLL #2054
Greg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to all
Fans/Propellers - Are you doing them?
There was a lot of discussion at the beginning of the build season about fans and propulsion and I'm curious to see how many teams are following through with it. There were a few pictures and videos early on, so if you're willing to, let us know if you are planning it as part of your final design.
If you aren't worried about your design, you could always post your ideas on the fans, etc.
Unread 25-01-2009, 17:11
Urban Hawk Urban Hawk is offline
Head of R&D and Head of Scouting
FRC #1886
Team Role: Scout
Urban Hawk is infamous around these partsUrban Hawk is infamous around these partsUrban Hawk is infamous around these parts
Re: Fans/Propellers - Are you doing them?
well you said post my ideas on the fans so here it is:
we aren't planning fans on our robot because they might provide some power but on the whole they probably won't do much. the only real effective means would to be to use a vacuuming unit with its intake on the bottom and its outage on the top to pull it down on the field. The problem with that though is that vacuum's use allot of power and can easily drain a battery. So because of that we decided not to do either.
FEAR THE HAWK!!!
Unread 25-01-2009, 17:22
Dan2081's Avatar
Dan2081 Dan2081 is offline
AKA: Dan
FRC #2081 (Icarus)
Dan2081 is a splendid one to beholdDan2081 is a splendid one to beholdDan2081 is a splendid one to beholdDan2081 is a splendid one to beholdDan2081 is a splendid one to beholdDan2081 is a splendid one to beholdDan2081 is a splendid one to beholdDan2081 is a splendid one to behold
We were speculating and conducting tests on a few different types of fans, and a small prop. Although we found out that we could nearly double our thrust with 3 different fans if they were all on the robot, it wouldn't leave any room or weight for any type of successful manipulator. We decided that we are not using fans
09 IRI #7seed and Semifinalists
09 BMR GM Industrial Design
08 BMR Engineering Inspiration
08 Archimedes #5 seed
07 BMR Rookie All-Star
Unread 25-01-2009, 18:57
ZakuAce's Avatar
ZakuAce ZakuAce is offline
AKA: Garrett
FRC #2077 (Laser Robotics (Alumni))
ZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of light
Yep it really did not seem practical to us. Too much weight, too much power consumption, and too much room.
Unread 25-01-2009, 19:02
writchie writchie is offline
Engineering Mentor
AKA: Wally Ritchie
FRC #2152 (Team Daytona)
writchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond repute
We have a modular vectored thruster that provides 5 lbf and could supply as much as 8 lbf if we can find a way to machine our custom props.
There are issues with optimal shooter angle so we might loose it at our critical design review tomorrow or in final testing.
Unread 25-01-2009, 19:05
Rick Wagner's Avatar
Rick Wagner Rick Wagner is offline
FRC #3008 (Kalani Robotics)
Rick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to behold
A few extra ounces of pushing power should always be welcome on the slippery surface this year. I'm surprised not many seem to be doing it because it is so simple to implement. Just take a spare motor and put a hobby shop propeller on it, mount the motor with a hose clamp behind a screen for safety. Have the software turn it on when the wheel motor current (or command level) exceeds some forward value.
Unread 25-01-2009, 19:19
Engineering Mentor
AKA: Wally Ritchie
It's a bit more than this but not that difficult.
The major weight and effort is the safety cage. When you throw a prop it can do serious damage and may bounce off obstacles without loosing all that much. The trailing edge is sharp. IMHO only a complete shroud that prevents an exploding propeller from escaping will satisfy the Inspectors.
Props must also be balanced or the vibrations are likely to lead to failure.
Unread 25-01-2009, 19:27
It's simple, but not necessarily as effective as you might think at first.
You'd be surprised at just how much thrust a propeller system can lose when you add the safety screen. In some cases, it drops the force to less than a fourth of what it would be otherwise.
Unread 25-01-2009, 19:42
I flew model airplanes many years ago, and while I have broken nylon propellers, I had to crash the airplane to do it. We used to balance propellers on a pair of single edge razor blades.
Unread 26-01-2009, 08:21
zrop zrop is offline
FRC #2526
zrop has a spectacular aura aboutzrop has a spectacular aura aboutzrop has a spectacular aura about
Team 2526 is using only props for propulsion. As long as we keep our weight down... we should be able to blow the competition away. =P
Unread 26-01-2009, 09:11
Jared Russell's Avatar
Taking a year (mostly) off
The amount of room occupied by fans and the necessary guards are what deterred us from pursuing this idea further.
Unread 26-01-2009, 22:33
DonRotolo's Avatar
Back to humble
FRC #0832
Although our team has many fans we won't be using them for propulsion (not at this point, at least) primarily because of the safety and noise aspects.
Unread 27-01-2009, 12:54
AHS1599's Avatar
AHS1599 AHS1599 is offline
Parent/Mentor
FRC #1599 (Techromancers)
Team Role: Parent
AHS1599 is an unknown quantity at this point
We did some tests in the first week with a prototype on the actual floor material with the correct wheels. While it did move the bot, it was inefficient so we opted for a different design...
2007 NASA/VCU Regional Semi-finalist
Unread 28-01-2009, 21:29
Gboehm Gboehm is offline
FRC #1516 (Grizzlies)
Gboehm is a splendid one to beholdGboehm is a splendid one to beholdGboehm is a splendid one to beholdGboehm is a splendid one to beholdGboehm is a splendid one to beholdGboehm is a splendid one to beholdGboehm is a splendid one to behold
Your Idea isn't as original as you think, Brabham used the Idea in the 1978 Formula 1 season, It was banned after one race.
2005 SVR Highest Rookie Seed
2005 SVR Rookie All Star
2006 WRRF Cal Games Winner
2007 SVR Winner
2007 #7 Alliance Captains Archimedes Divison
"Any sufficiently advanced technology is indistinguishable from Magic." - Arthur C. Clarke
Unread 28-01-2009, 21:49
Only after the idea was invented by Jim Hall in his Chaparral 2J Can-Am car, which was banned after one season in 1970.
What are you doing for the flooring? Petey Kit & Additional Hardware 21 06-01-2009 20:01
Drivetrains - How are you doing it? Tom Line General Forum 16 28-03-2008 09:12
What are you doing Saturday night? Titan Championship Event 9 09-04-2007 12:58
What are you doing this year? 358_4_Life Rules/Strategy 4 16-01-2007 17:23
10th Anniversary Teams - what are you doing? archiver 2000 2 23-06-2002 22:55
