Go to Post I'm probably going to make somebody feel old right now... - NorviewsVeteran [more]
Unread 27-01-2009, 13:05
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Quick release
Originally Posted by Dad1279 View Post
Fishing reel? Motor to wind, servo to release.
Fishing reel releases tend to lock when under load. Some of them lock very effectively even under a light load. AndyMark Shifters and other dog or meshing shifters are going to exhibit some amount of locking under load as well, simply because more load means more friction on the meshing parts. They probably will still be shiftable, but it's never going to be as easy as when they're unloaded.
Unread 27-01-2009, 13:43
Team 135 Team 135 is offline
FRC #0135 (Penn Robotics)
Team 135 will become famous soon enough
Re: Quick release
I would use a small pneumatic actuator that came in the kit. We used this on a prototype to hot swap the trailer and it worked great even under tension.
Unread 13-01-2010, 18:47
bhsrobotics1671's Avatar
bhsrobotics1671 bhsrobotics1671 is offline
Andrew Nabors
AKA: Andrew Nabors
FRC #1671 (Buchanan Bird Brains)
bhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to behold
Re: Quick release
Could you PM me or provide me with more information as to how this winch system worked? We are very interested in this type of design. Thanks!
Buchanan Bird Brains - FRC Team 1671
2015 FIRST World Champions
118, 1678, 1671, 5012
Unread 13-01-2010, 19:11
Pneumaticsman's Avatar
Pneumaticsman Pneumaticsman is offline
AKA: Mitch guzman
FRC #1566 (Ammoknights)
Pneumaticsman will become famous soon enoughPneumaticsman will become famous soon enough
Send a message via MSN to Pneumaticsman
Re: Quick release
We are thinking of using a winch as well. We are thinking of having a winch to pull some cable back, which loads tension on some surgical tubing. Once tensioned, we plan on releasing a "clutch" that will disengage the winch and release the tension in the surgical tubing, thus kicking the ball.
be prepared for the unexpected
pic: Bike quick release part 2 falconmaster Extra Discussion 4 24-01-2008 07:39
Quick Vacuum Release Calvin_1631 Pneumatics 8 05-02-2007 20:49
Quick release wire harness mechanicalbrain Electrical 2 08-01-2006 15:36
openFIRST Release -- 'Twas the Release Before Christmas Timothy D. Ginn FIRST-related Organizations 3 25-12-2003 23:44
Quick release battery connector and 120 amps n[ate]vw Electrical 6 18-01-2003 23:41
