Go to Post Public Service Announcement: Pressing the spacebar when the robot is enabled isn't nearly as funny the forty-second time. - Taylor [more]
Unread 27-01-2009, 13:27
eNyoron eNyoron is offline
Captain, Programmer, Clueless.
FRC #1787 (untitled.txt (as of now))
eNyoron is an unknown quantity at this point
Send a message via AIM to eNyoron
Help, our driver station is permanately stuck in enabled.
I don't think it's a problem with the dongle, considering the driver station is enabled even when the dongle is removed completely. Power resets haven't worked, is there any known solution besides possibly a factory reset?
Unread 27-01-2009, 13:35
Team 135 Team 135 is offline
FRC #0135 (Penn Robotics)
Team 135 will become famous soon enough
Re: Help, our driver station is permanately stuck in enabled.
Your controller should disable when there is no connection detected with the dongle. A factory reset may be in order.
Unread 27-01-2009, 13:39
What I thought... and feared. I understand I'll need to reinstall the firmware onto the Driver Station, but the cRIO won't need any further modification, right?
Unread 27-01-2009, 14:40
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Before you do anything you should contact FIRST or KwikByte, and ask what they suggest. The last thing you need to damage the DS because you did something you shouldn't have.
Eric Haskins KC9JVH
Unread 27-01-2009, 15:43
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
That happened to ours the other day. I was having trouble getting it to communicate with the cRIO, so i set the team numbers to 0000. After that our DS locked up and wouldn't change to disable or enable, and wouldn't change to autonomous. Power cycling did not help either.
So, i went to try to redo the update. I started powering it up while holding those two arrow buttons down, and didn't even get very far, and our DS started responding normally again.
Driver station problem team2491 FRC Control System 7 31-01-2009 00:18
driver station and cRIO firmware update help asianfez123 FRC Control System 1 16-01-2009 02:34
2nd Driver Station bcharbonneau General Forum 2 09-01-2009 14:19
Help with updating firmware on Driver Station urg8rb8 FRC Control System 3 28-12-2008 02:53
Driver Station Help.. 1708xMr.Roboto FRC Control System 8 22-12-2008 15:24
