Go to Post The 2008 team is not the 2007 team and won't be the 2009 team. Every year is a new year and a new opportunity for growth and development as a FIRST team. It's very cool. - JaneYoung [more]
Unread 27-01-2009, 14:00
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Re: [FTC]: Tips page on using FTC Encoders with LabVIEW
Originally Posted by jbbjjbt View Post
Phil,
But sometimes either the encoders don't read or the loop processes to slowly and the robot goes way past where it is supposed to stop. It is somewhat random as it will work one run and not the next. It is frustrating and time consuming.
Have you seen this? Do you have any ideas how to fix it?
Thanks,
Hi
I still see times when for some reason the NXT stops being able to talk to the Motor controller. When it happens, it usually continues for about 2.5 seconds, and then corrects itself. Not helpfull if you are planning a complex sequence.
The encoders keep running insider the speed controller, but don't get seen by the NXT untill after the bus fault clears.
Are you keeping track of your 12V battery voltage? My experience is that these "random" problems occure much more if the battery voltage is let go below 13.5 V (some have said 13.75V)
This isn't a great lot of help, but we've just resigned ourselves to keeping the battery charged and putting up with random motions.
I'll say that we also get our best results if we power down BOTH the NXT and 12V betwen each run. It just "seems" to help. The glitch seems to occur whenever we forget this power-cycle step.
Phil.
Phil Malone
http://www.GEARSinc.org
[FTC]: LabVIEW Programming Template for FTC Team 288 FIRST Tech Challenge 30 06-02-2010 17:49
[FTC]: FTC read encoders vi Jim.D FIRST Tech Challenge 8 26-12-2008 23:42
[FTC]: Progress report on using encoders PhilBot FIRST Tech Challenge 11 14-11-2008 14:01
[FTC]: First problem with FTC and LabView.....? PhilBot FIRST Tech Challenge 5 07-11-2008 10:36
[FTC]: FTC Servo-Motor Problem with Labview dnhansen FIRST Tech Challenge 1 26-10-2008 00:43
