Go to Post I challenge the status quo - it's just me. - techhelpbb [more]
Unread 27-01-2009, 14:38
Mac Generals Mac Generals is offline
Tony-Team 1358 Advisor
FRC #1358 (Generals)
Mac Generals is an unknown quantity at this point
flashing orange
we have an issue our victors are flashing orange we have no real electrician on our team and are trying to figure this out, any help would be helpful
"We Shall Return"
Unread 27-01-2009, 14:48
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: flashing orange
Short Answer: They're not getting a signal from the cRIO.
Long Answer: Check all connections. Ensure that you have the driver station up and running properly. Router needs to be on. Gaming adapter on. Make sure you set everything up properly per the instructions. Make sure you have code loaded.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 27-01-2009, 15:48
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
Re: flashing orange
yeah. check your PWM cables. OR check your code.
Unread 27-01-2009, 16:44
cabbagekid2 cabbagekid2 is offline
#0368 (Kika Mana)
cabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura about
Re: flashing orange
Yup, double check that the PWM cables are plugged in correctly (black wire on the inside) and all the way in. Also, make sure your driver station is enabled, not disabled.
Unread 27-01-2009, 17:29
jerry w's Avatar
jerry w jerry w is offline
Free Agent Mentor
no team (Team Krunch)
jerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud of
Re: flashing orange
also, in the code, make sure that the watchdog is fed. otherwise they will never stop flashing.
if you feed too slowly, the flashing will start again between feedings.
Happiest when people tell the truth... However, I am blessed with many friends.
Unread 27-01-2009, 17:36
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Re: flashing orange
You might want to consider trying the FRC Diagnostic Window and check the Robot Signal Light status.
Russ
http://thinktank.wpi.edu/article/138
http://decibel.ni.com/content/docs/DOC-3120
Unread 28-01-2009, 08:10
Re: flashing orange
It is very easy to miss the internal connector on the Victor as you insert the PWM cable. It is easy to miss when the pins are slightly bent. When fully inserted the shell of the PWM connector will only have 1/8" showing above the shoulder of the Victor body.
Unread 31-01-2009, 14:30
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: flashing orange
We are having the same problem today. We have been loading our code successfully all build season and it has been working great. Today when we attempted to load the latest version none of the speed controllers are able to get a signal from the digital sidecar.
The Robot Status Light on the Digital Sidecar is solid during our code and when we run the FRC Diagnostic Window. But the victors are all still not getting signal. I have gone over every cable on the robot and they are all wired properly. This problem will not go away. We have deployed multiple versions of code with multiple computers and this is still not fixing the problem.
Does anyone have any idea on what problem might be?
Unread 31-01-2009, 16:11
Engineering Coach
Re: flashing orange
So after 3 hours of trouble shooting we eventually reflashed the cRIO and this fixed the problem. However what we don't know is what causes the cRIO image to fail like that. We think a programmer might have started deploying code while the robot was enabled and running, would something like that cause the image to fail?
Unread 31-01-2009, 23:39
GRS GRS is offline
FRC #1764
GRS is an unknown quantity at this point
Re: flashing orange
If you mean deploying some code, then deploying another, self-contained, piece of code while the first piece is running, then no, this would not cause the image to fail horridly.
Unread 01-02-2009, 11:18
nathanww nathanww is offline
Hacker
FRC #1678 (Citrus Circuits)
nathanww is just really nicenathanww is just really nicenathanww is just really nicenathanww is just really nice
Re: flashing orange
Were you trying to load code to RAM without undeploying first? This can cause weird results.
Get yer robot source code here!
Flashing compact rio? excel2474 Programming 3 06-01-2009 14:10
OI Robot Feedback LEDs flashing Sirius Technical Discussion 4 10-11-2007 14:10
Code Flashing Issues bluenp Programming 4 07-11-2007 23:43
Flashing Battery Light Max Brin Technical Discussion 3 12-01-2006 11:46
flashing LEDs jacob_dilles Electrical 1 22-02-2004 21:52
