Go to Post What about marriages ended by FIRST. I know that by Presidents Day my wife is not real happy with me :) - IndySam [more]
Unread 27-01-2009, 15:02
Felipe Sagui Felipe Sagui is offline
FRC #1382 (EtepTeam)
Felipe Sagui is an unknown quantity at this point
Send a message via MSN to Felipe Sagui
Using Sensors in Autonomous Independent
I have a doubt about how use sensors in autonomous mode.
I create my own VI with the Gyro PID logic, when I put it on Basic Robot Main inside the "TeleOp Execute" case it works, but when I put this on Autonomous Independent VI it doesn't works.
Can anyone show me a solution or ideia to solve this problem?
Felipe Cezar Salgado
ETEPTEAM #1382
Unread 27-01-2009, 16:53
Re: Using Sensors in Autonomous Independent
Sorry , the other programmer from my team forgot the while loop on the autonomous independent, so it was only running 1 time.
This problem is solved.
Thanks and sorry.
ETEPTEAM #1382
Unread 27-01-2009, 17:25
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Thanks and sorry.
I sounds to me from what I am reading here that you have the Gyro code running in two separate locations. There really is no need to do this. It is redundant, eats up more program space and may not work quite like you want it to.
If you run the gyro vi in it's own while loop, outside of the tele-op loops in Basic Robot Main, it will run regardless of whether you are in tele-op or autonomous. Then all you need to do is create Globals for the angle and/or rate outputs,to be accessed from within the "Autonomous Independent" vi, and you should be good to go.
Using sensors Bronson Electrical 5 09-01-2008 23:17
Using Sensors thoughtful Programming 11 16-12-2003 10:28
Anyone using sensors??? Willum Robot Showcase 42 25-02-2003 18:57
pre-built autonomous sensors? BandChick Technical Discussion 4 05-01-2003 22:06
Is anybody using the sensors? Jeremy L Rules/Strategy 26 03-03-2002 22:42
