Go to Post we've got three years to perfect it. And then... who knows? - Amanda Morrison [more]
Unread 27-01-2009, 08:45
xitaqua xitaqua is offline
COPUS MEMBER
no team (BERSDT)
xitaqua is a splendid one to beholdxitaqua is a splendid one to beholdxitaqua is a splendid one to beholdxitaqua is a splendid one to beholdxitaqua is a splendid one to beholdxitaqua is a splendid one to beholdxitaqua is a splendid one to behold
Week 4 - Building The Crate
Hello All,
It is exciting to be on Week 4, I have been visiting many teams here in the St. Louis Area and have seen many exciting things !!!!.
Does anyone have a BOM (Bill Of Material) for building a crate ?. Something a team can take to the near by hardware store and purchase ?.
I would like to take back this type of information to the rookie teams I plan to visit this week.
Cheers,
Marcos.
Unread 27-01-2009, 09:30
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Week 4 - Building The Crate
five sheets of 7/16" x 4' x 8' plywood, ten 8' 2x4s, one 8' 4x4, and a box of 1.5" deck screws. And some big screw eyes and rope to tie the robot down.
That's off the top of my head...from last year's crate. Looks like we'll be able to use it again!
Unread 27-01-2009, 12:13
Have you read Section 4 yet? It has the general requirements. If you know the size, you can run the numbers.
Squirrel has it about right, though. The 2x4's are for interior support, so you can't have too many. Leftover scraps can be used to help tie down the robot
Unread 27-01-2009, 12:27
COPUS MEMBER
no team (BERSDT)
Very cool !!!.
Here is what I have from squirrel info :
QTY MATERIAL DESCRIPTION
5 PLYWOOD 7/16” x 4’ x 8’
10 2x4 8’
1 4x4 8’
BOX DECK SCREWS 1.5”
??? SCREW EYES To tie the robot down.
Cheers,
Marcos.
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
When you are building your crate remember that other crates chould be stacked ontop of yours for storage during the regional. No need to freak out about it as most solid crates wont have a problem with this, but some are not so solid.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 27-01-2009, 13:26
MrForbes's Avatar
AKA: Jim
Also remember that you want it to weigh LESS than 400 lbs, with the robot (and whatever other stuff) inside. You can use slightly thinner plywood, 3/8" is the minimum I would use. And you can possibly use 2x2" pieces of lumber instead of 2x4s, but they would more likely to split.
If you study the picture I posted above, you'll see that it is designed to be built as several subassemblies (and can be disassembled into those subassemblies easily). The sides each have four 2x4s screwed to them, the top and bottom have two 2x4s on them, and the rear and (removed) front panel are just plywood. There is a lip along the bottom where the plywood extends past the rest of the crate, so that the front panel can rest on it to make it easier to hold while screwing it into place. The bottom has additional 2x4s to support the frame of the robot, the wheels sit in the recesses between the 2x4s so that they are not touching the crate...that way, they won't be damaged by rough handling or rough roads.
I think you might also need some 3" long screws to attach the sides to the bottom, and for other miscellaneous uses.
Unread 27-01-2009, 13:38
Team 135 Team 135 is offline
FRC #0135 (Penn Robotics)
Team 135 will become famous soon enough
Yes really be careful when it comes to weight, out crate has been over for a few years now and every year we pay extra because of it. Plus we have to lift it into the back of a semi and a few pounds makes all of the difference when you are lifting it above your head.
The other thing to be careful of is being able to open and close the crate multiple times without compromising the integrity. While we were at Purdue last year we were frantically drilling new holes because the screws had pulled out of the wood.
Unread 27-01-2009, 16:05
COPUS MEMBER
no team (BERSDT)
Hello All,
I have enclosed an estimative for the Crate #1 mentioned by Squirrel, it comes about at $87.50
Team 135 brings a good point about "...being able to open and close the crate multiple times without compromising the integrity..."
Does anyone have a list of material to make a "door" for a crate ?
If someone post the material necessary, I will go get an estimate for a Crate in which I will creatively call Crate #2.
Unread 27-01-2009, 16:08
Originally Posted by xitaqua View Post
Hello All,
What you might do is add the following to your list:
2-Hinges (need to be able to go around the outside, or on the inside.
1- padlock
1- padlock mounting hardware--attach to the outside opposite the hinges. Make sure that you keep the key/combination handy.
Attach the hinges to the "door" side. Put the padlock hardware so that it can lock the crate. Done.
Unread 06-02-2009, 09:55
COPUS MEMBER
no team (BERSDT)
Talking Re: Week 4 - Building The Crate
Hello Eric H,
Thanks for your ideas for a crate w/ a door.
The estimate is at $108.52
Enclosed is the spreadsheet with 2 different estimates.
In St. Louis we might have at least 4 rookie teams that will need to build a crate, and so far I think they have not started on this project.
I might think this might be down to the wire on President's Day.
Unread 06-02-2009, 10:28
MrForbes's Avatar
AKA: Jim
Using screws to hold the opening sides of the crate on provides more structural integrity than using hinges and a hasp. The "stacking" strength of the crate I showed is based on the sides all being screwed in place, not hinged.
Unread 06-02-2009, 10:36
COPUS MEMBER
no team (BERSDT)
Hello squirrel,
I understand that if we put hinges on the design you mentioned it might compromise the structural integrity.
Is there anything that can be done so we have a sound design that has hinges ?.
What other material might be needed ?.
Cheers,
Marcos.
Unread 06-02-2009, 10:51
MrForbes's Avatar
AKA: Jim
It is a matter of design, not material. I do not see a need for a hinged door, so I have not designed a crate with one. Maybe someone with a crated designed for an opening door will speak up?
Unread 06-02-2009, 11:56
COPUS MEMBER
no team (BERSDT)
Good Point,
Maybe someone has a picture of a crate that has a hinge .....
Cheers,
Marcos.
Building the FRC Crate guyserman82 General Forum 20 05-12-2008 21:08
**FIRST EMAIL**/"Building the Crate; Shipping the Robot" Teleconference KathieK FIRST E-Mail Blast Archive 0 05-02-2008 14:58
the size of the shipping crate, the maximum dimensions?????????? MASherry General Forum 5 13-01-2004 22:30
FIRST to reduce 6-week building period to 5-week archiver 2001 12 24-06-2002 01:27
Help on crate/cart building archiver 2000 4 23-06-2002 22:06
