Go to Post The math isn't that hard. It's just a tool, like a screwdriver or soldering iron. Sure you get tired of picking up the same old thing everyday, but when you have to tighten a screw you still reach for the screwdriver. - Al Skierkiewicz [more]
Unread 27-01-2009, 16:47
thoughtbubble thoughtbubble is offline
FRC #2143
thoughtbubble is an unknown quantity at this point
Re: Did anyone use all 4 CIM motors for the wheels
Quick Question in relation here, is the limit for the motor this year only apply to the cims? We checked the rules but didn't find anything there any thoughts?
Unread 27-01-2009, 20:07
Rick Wagner's Avatar
Rick Wagner Rick Wagner is offline
FRC #3008 (Kalani Robotics)
Rick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to behold
It's in the Robot rules. You may use only the motors in the kit plus two additional CIMs.
Unread 28-01-2009, 07:46
From Rev E...
<R51>
Motors specifically permitted on 2009 FRC ROBOTS include:
A.
All motors, actuators, and servos provided in the 2009 Kit Of Parts,
B.
An unlimited number of COTS servos with a maximum output torque of 55 oz-in and maximum rotational speed of 100 rpm at 6 Vdc (e.g. HITEC model HS-322HD or HS-325HB servos, as provided in the Kit Of Parts),
C.
An unlimited number of FIRST Tech Challenge (FTC) servos (HITEC HS-475HB servos),
D.
One or two additional 2-1/2” CIM motors (part #FR801-001 and/or M4-R0062-12) in addition to those provided in the Kit Of Parts. This means that up to four, and no more, 2-1/2” CIM motors can be used on the ROBOT.
E.
COTS motors used as one-to-one replacements (i.e. identical vendor and part number) for motors, actuators and servos provided in the 2009 Kit Of Parts that may have failed or become inoperable.
Emphasis mine.
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
[FVC]: Curiosity: Did anyone use the aluminum parts? Billfred FIRST Tech Challenge 6 29-04-2007 17:26
2006: Did anyone use the Mabuchi motor? Billfred Motors 18 28-04-2006 21:44
How did you use the FP motors? Validius Motors 25 02-03-2005 01:30
Can anyone confirm that the CIM and Drill motors are the same as last year? Jeremy Technical Discussion 2 12-01-2004 21:54
