Go to Post I like this thread because it means I don't have to leave my house to find something to complain about! - PayneTrain [more]
Unread 27-01-2009, 17:29
saaby's Avatar
saaby saaby is offline
AKA: Taylor Cannon
FTC #0127 (Fighting Pickles)
saaby can only hope to improve
[FTC]: Servos
My team is having a large problem with getting the servos to move in our program. We are using robotc. There is a servoTarget[servoname] function and we were wondering if this was the best and/or only way to control the servos? Even when we use this function it does not seem to be very efficient and was not even working in our first attempts to use it.
Unread 27-01-2009, 18:08
ttldomination's Avatar
Sunny
Re: [FTC]: Servos
Well,
You would need to figure out if your problem is physical or code. Set up a single servo and see if the servo changes to the position you want to determine exactly what kind of problem you have.
1648: 2013-2014
5283: 2015
Unread 27-01-2009, 23:17
saaby's Avatar
AKA: Taylor Cannon
Re: [FTC]: Servos
We tried that but it didn't work, hence my original question, is it the only way to control the servos? If there is another way to control the servos then we could at least test the servo to see where our problem is. From what I have read the only way to control the servo is servo[] and servoTarget[] which is just an alias pointing to the servo[] function.
Unread 28-01-2009, 17:13
Sunny
Re: [FTC]: Servos
To my knowledge, those are the only ways to do the servo position. Uh, let's try these steps.
1. Check your hardware. Are your motors working? Is everything wired properly? I think your wiring's funky considering the test Servo did not work.
2. Make sure that you have the proper setup in the motors and servos set up menu in RobotC.
Let me know if either of these work.
1648: 2013-2014
5283: 2015
Unread 31-01-2009, 13:17
hammy's Avatar
hammy hammy is offline
FRC #1622
hammy is an unknown quantity at this point
Question Re: [FTC]: Servos
our team is having the same problem and we have tried your three steps
Unread 31-01-2009, 17:07
Sunny
Re: [FTC]: Servos
If your servos are facing each other, then go ahead and change their direction in the code as well. Because they are going opposite directions, now that they are facing each other. let me know if that solves the problem.
1648: 2013-2014
5283: 2015
Unread 31-01-2009, 20:38
saaby's Avatar
AKA: Taylor Cannon
Re: [FTC]: Servos
Thanks for the replies but we figured it out...kinda. I don't know why they didn't work when we didn't have our arm attached to them, but in the end our arm was too heavy for the servos to lift so we had to rig it using NXT motors. servoTarget() was the funtion we used and worked pretty well when assisted by the NXT motors
[FTC]: [FTC]: Can any one explain to me just how powerful the servos are? sullivan_owns FIRST Tech Challenge 19 02-12-2008 16:06
[FTC]: FTC Controller Station Connectivity (Bluetooth and USB) Issue jbbjjbt FIRST Tech Challenge 6 05-11-2008 11:49
[FTC]: Rookie Team Needs Help With Tetrix FTC Kit! rjustice4 FIRST Tech Challenge 8 05-10-2008 09:44
[FTC]: FTC]: FTC Champ Tournament - Ontario (Scoring Breakdown) Mr. Lim FIRST Tech Challenge 2 03-03-2008 11:54
[FTC]: [FTC]: Ontario Provincial FTC Start/End Times cbhl FIRST Tech Challenge 8 16-12-2007 13:37
