Go to Post I care that teams took some time to put in safe guards to prevent shrapnel hitting people because I'm selfish and I enjoy the use of all of my limbs. - Andrew Schreiber [more]
Unread 27-01-2009, 19:47
Ibanez549's Avatar
Ibanez549 Ibanez549 is offline
AKA: Chris
FRC #0549 (Devil Dawgs)
Ibanez549 is an unknown quantity at this point
Send a message via AIM to Ibanez549
Talking Color tracking not working.
Hey, im from team 549 and we are currently working on our color tracking program in labview. We downloaded the Two color tracking program from the first website to use. Our problem is that when we try to use it the camera scans, then finds the target, and then seems to go all the way left and start scanning again right away. Is there some thing we are doing wrong or something not set? We havent changed the program we downloaded at all. Thanks for the help.
Unread 28-01-2009, 01:13
Re: Color tracking not working.
If your camera is mounted with the power and network connectors at the top, it's upside down from the way the software expects. It will tend to "run away from" the target instead of tracking it.
If this is the case, you can connect the camera directly to your computer and log on to it (user FRC, password FRC) to configure it to rotate the image 180 degrees.
It's also possible to build the pan/tilt assembly as a mirror image of the intended design, in which case the tilt servo is going to drive the camera up when the software thinks it's going down. Looking into the camera lens, the tilt servo ought to be to the camera's left.
If neither of these is your issue, i'm not sure what else to suggest.
Unread 28-01-2009, 08:11
The proportional constants for determining how the gimbal moves due when the image isn't centered are on the gimbal control subVI. I believe one is positive and one is negative. If you think one is backwards, negate it. If that fixes it, be sure to make current value default on the control.
Greg McKaskle
Two Color Tracking Demo Bharat Nain Programming 43 25-01-2009 18:58
Camera Tracking not working? NinJA999 C/C++ 0 25-01-2009 15:28
Video: Color Camera Tracking laultima Programming 10 22-01-2009 22:43
Team 399 Color Tracking EricGoodchild Robot Showcase 2 15-01-2009 22:38
Tracking Color? haywirerobotics Programming 0 14-01-2006 13:55
