Go to Post Try to remember, FIRST is like life, it is about the journey not the destination. - rees2001 [more]
Unread 27-01-2009, 20:58
Dave McLaughlin's Avatar
Dave McLaughlin Dave McLaughlin is offline
Dave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond repute
pic: Skunkswerve Module Cross Section
Unread 27-01-2009, 21:00
Re: pic: Skunkswerve Module Cross Section
This is the final design for the swerve modules we are using on this year's robot. I would be happy to answer any questions.
Unread 27-01-2009, 22:00
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Looks good. How much does it weigh, and can you put up an isometric view? I'm having a hard time visualizing the bearing mounts for the sprocket-bevel gear shaft.
Unread 27-01-2009, 22:14
Lesman's Avatar
Lesman Lesman is offline
FRC #1014 (Bad Robot)
Lesman will become famous soon enough
Our design is similar, I'm just curious as to how you guys built it. Our modules are milled and assembled from various pieces of square tubing.
Unread 27-01-2009, 22:17
There is a bearing on each side that is press fit. We some left material in the bottom of the hole for the bearing that keeps them from being pressed through. We drilled and tapped the shafts so that we can secure them in the opposite direction with a washer and a bolt. I'm uploading an Iso view right now.
Unread 27-01-2009, 22:21
We used 4x4 aluminum extrusion (1/4 W) and 1/4 plate welded to the top. Then our new machining sponsor CNCed out all the holes and add the curve at the bottom that can be seen in an Iso view (Another pic is uploading as I post this).
Unread 27-01-2009, 22:35
The Isometric view can be seen here: http://www.chiefdelphi.com/forums/sh...threadid=73090
Unread 30-01-2009, 21:43
5n1p3r's Avatar
5n1p3r 5n1p3r is offline
IM 5n1p3r
AKA: Matthew
FRC #0714 (Team Panthera)
5n1p3r will become famous soon enough5n1p3r will become famous soon enough
Send a message via AIM to 5n1p3r
Thumbs up Re: pic: Skunkswerve Module Cross Section
ok now this is cool, i haven't seen much people put the split view to work so i gotta give you that.
Unread 02-03-2009, 16:59
big1boom big1boom is offline
Chains=Fun
FRC #2022 (Titan Robotics)
big1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of light
looks fairly similar to 2022's swerve modules. Except that we CNCed the parts out of 1/8" aluminum plate and welded them together. So our modules are bigger.
Unread 02-03-2009, 18:01
Edit
Unread 02-03-2009, 18:03
I'm interested as to how you ensured that the holes for the drive shaft, and other holes that need to be precise, lined up after welding. With most of our welded parts was eperience at least some warping, which is why we chose to have the "cans" welded and then machined.
I was also wondering how large your modules are and how much they weigh for comparison. Thanks in advance.
Unread 02-03-2009, 18:13
Chains=Fun
http://www.chiefdelphi.com/forums/sh...ad.php?t=75407
Each wheelbox has this lazy susan on top and bottom
http://www.mcmaster.com/library/20080826/1544T100L.GIF
I don't have the exact specs but I am guessing that they are each 8 or 9 inches tall, then +2 inches for the turning chain and drive chain. So the entire drivebase is less than 1 foot tall.
Unread 02-03-2009, 18:40
I envy how easy it must be to get your hands inside the module for maintenance. The top of our drive base frame is also about 1' off the floor, with steering and power chains on top. Do you employ differential power between the left and right side? Our drive does and this allows us to change from "half-swerve" to "crab" to "tank" all without any mechanical changes.
Unread 02-03-2009, 19:06
Chains=Fun
No differential. All wheels are powered the same amount. But we are able to implement a type of "Warthog" steering where to the front wheels turn opposite of the back wheels.
It is fairly easy maintence on the swerve moduals.
We have around a third of an inch of ground clearance.
Unread 02-03-2009, 19:19
We use the same type of 4x4x4 or "warthog" drive when we are swerving. We are using a three axis joystick and use x and y to translate or "crab" relative to the front of the robot. When we use the z axis, yawing on the joystick, the modules are oriented "warthog" style AND receive left-right differential power. We have found that this is quite effective.
pic: Skunkswerve....team 1983 Bob Steele Extra Discussion 22 30-01-2009 22:09
pic: Rage 173 cross section of robot in SolidWorks TriggsJr Extra Discussion 20 05-05-2005 10:58
Error - section 'UTIL_LIB' can not fit the section. Section 'UTIL_LIB' length=0x00000 BookerT Programming 13 27-01-2005 09:49
Error - section 'UTIL_LIB' can not fit the section. Section 'UTIL_LIB' length=0x00000 BookerT Programming 0 25-01-2005 19:17
pic: 217 Gen 2 Crab Module Section view CD47-Bot Robot Showcase 2 28-04-2003 18:26
