Go to Post To put it simply, its clearly become this. The teams that can score a lot, do well. Rather shocking, isn't it? It doesn't matter if you're a shooter, dumper, power dumper, gravity dumper, spitter, flinger, dunker, shumper, barfer, dropper, or whatchamacallit. Points are points. - Looking Forward [more]
Unread 27-01-2009, 22:32
Dave McLaughlin's Avatar
Dave McLaughlin Dave McLaughlin is offline
Dave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond repute
pic: Skunkswerve Module Iso View
Unread 27-01-2009, 22:34
Re: pic: Skunkswerve Module Iso View
Each module is about 5.5 lbs. fully assembled. Any and all questions are welcome
Unread 27-01-2009, 22:35
Hal9000's Avatar
Hal9000 Hal9000 is offline
Machining Addict
FRC #1983 (Skunkworks)
Hal9000 is an unknown quantity at this point
after facing several problems we are currently in the process of deciding what to use as an alternative to keyed shafts
Unread 27-01-2009, 23:00
REVving up for a new season
FRC #2848 (All-sparks)
Hex shafts work great. you can either find someone with or buy a hex broach. or even easier buy hubs from AndyMark that are prebroached.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 27-01-2009, 23:03
run the trap!!!
Team Role: Human Player
What exactly was wrong with the keyed shafts?
-Philip J. Fry
Unread 27-01-2009, 23:10
Hal was a bit quick to insist that we are looking for an alternative to keyed shaft. We encountered a small problem with holding one of our keys in place, but we have already figured out a way to address the problem. Thank you for the quick suggestion of hex shaft, but we intend to stick with the keyed shaft we have now.
Unread 27-01-2009, 23:35
run the trap!!!
If it is machined correctly the key should have almost a press fit so it doesn't twist around. You can hold it in place by simply having spacers on either side of the sprocket/gear to limit its movement or by using a setscrew.
IMO keyways are MUCH easier to make than hex parts. You need a lot of special tools and skills to correctly machine hex parts. Keyways are very easy.
-Philip J. Fry
Unread 27-01-2009, 23:38
Thank you for the advice, I think the approach that our drive team concocted is very similar to the one you proposed
Unread 28-01-2009, 18:17
jimbot's Avatar
jimbot jimbot is offline
FRC #2083
jimbot will become famous soon enoughjimbot will become famous soon enough
Is very cool, I wish we could build a swerve drive, but are you really going to use swerve this year?
"Though similar in apperance, unlike a firecracker, dynamite should not be held in ones hand when lit. Ohhhh..."
Unread 28-01-2009, 18:28
We asked ourselves the same question during brainstorming. Our answer is yes. We believe the ability to employ "thrust vectoring" (there is your arbitrary aviation connection of the day) will allow us to maneuver better than a differential drive. While we may not spend all match "strafing," the ability to use transverse friction for braking by orienting the wheels perpendicular to the direction of motion, and put all of our power into turning, rotating or driving makes us believe a swerve is worth the turmoil that usually comes with building one.
Unread 30-01-2009, 21:41
5n1p3r's Avatar
5n1p3r 5n1p3r is offline
IM 5n1p3r
AKA: Matthew
FRC #0714 (Team Panthera)
5n1p3r will become famous soon enough5n1p3r will become famous soon enough
Send a message via AIM to 5n1p3r
cool, i'd like to see what else you've done on inventor
Unread 01-02-2009, 11:45
Sam N.'s Avatar
Sam N. Sam N. is offline
FRC #1351 (TKO)
Sam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to behold
Send a message via AIM to Sam N.
This reasoning also drove our team to go with a steering chassis as well. (http://www.chiefdelphi.com/media/photos/32573?) We agreed that we wanted a chassis that "puts all of its energy in the direction we want to go." "Thrust Vectoring" is a good way of putting it.
Turning the front and back sets of wheels independently will deliver car-like steering (Front wheels turn +X degrees, rear wheels turn -X degrees). Orienting all the wheels the same way will deliver crab-like motion. Although this probably means we'll be "orbiting our trailer," we sill would like this functionality so we can escape from robot jams and possibly align our robot with the fueling station and outpost more accurately.
I'm really anxious to see pictures of the skunk module to see how it compares with our design. I think it's cool that a lot of teams arrived at this common design solution for this brain-scratching problem of a simulated lunar gravity.
Mitty Robotics Alumni
TKO 1351
Unread 07-02-2009, 16:45
megaman_22201's Avatar
megaman_22201 megaman_22201 is offline
FRC #1778
megaman_22201 is on a distinguished road
OMG!!!!
we have a concept just like that...but its a little different than that
-----Avinesh-----
---Team__1778---
pic: Skunkswerve Module Cross Section Dave McLaughlin Extra Discussion 35 03-03-2009 15:50
pic: rendered view of iso team 1708 D_Price Extra Discussion 2 15-02-2008 10:21
pic: Isometric View of A 6WD module Cody Carey Extra Discussion 8 04-01-2007 17:19
pic: Iso view CD47-Bot Robot Showcase 19 07-09-2004 17:38
pic: 217 Robot ISO view CD47-Bot Robot Showcase 8 01-03-2004 13:09
