Go to Post The students that I have known in FIRST over my 8 years of involvement have been far more inspired by the competition and some of the jaw dropping creations of "elite" teams than by anything that we made ourselves. - MattB703 [more]
Unread 27-01-2009, 16:21
gwilliam gwilliam is offline
FRC #1850
gwilliam is an unknown quantity at this point
Electrical board materials?
Hi all,
We have used plexiglass/lexan in the past and have had trouble with cutting and drilling. Has anyone used masonite successfully or unsuccessfully? Any problems you might forsee?
Jeff Gwilliam
Coach, Team 1850 Mechanicats
ACE Tech High School
Unread 27-01-2009, 16:28
roborat roborat is offline
roborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to behold
Re: Electrical board materials?
We have always used Lexan and had no problems with cutting or drilling. Plexiglass and lexan are two different materials and plexiglass with break and give you problems. We used 1/8 thickness on the bottom but used 1/16 on any covers and guards we needed.
Unread 27-01-2009, 16:36
dtengineering's Avatar
AKA: Jason Brett
Plywood works great...
Jason
Unread 27-01-2009, 16:40
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
We've used a fiberglass / balsa wood composite board that is very light, but very strong. It drills easily as well. We use a bolt-through design though.
Don't use plexiglass or acrylic. They crack and snap easily. Lexan is the way to go if you want to use something like it.
Plywood works great as well, just a little heavier than all the others. I know of some teams that also use peg-board, which you can get at Lowes or Home Depot.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 27-01-2009, 16:53
neoshaakti's Avatar
neoshaakti neoshaakti is offline
FRC #2554 (WarHawks)
neoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to behold
Send a message via AIM to neoshaakti
anyone have experience with recycled HDPE?
Unread 27-01-2009, 21:05
DonRotolo's Avatar
Back to humble
FRC #0832
HDPE is a bit heavy, but at maybe 1/4 or 3/16 inch probably plenty strong. But for that, 1/8" lexan is real easy to work with and beaucoup strong.
Unread 27-01-2009, 22:43
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Plywood has the advantage of being relatively stiff for the weight. We've used 1/8" Lexan in the past and had to brace it, this year we're using 3/8" plywood and it's plenty stout.
Unread 27-01-2009, 23:34
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
1/8 in peg board.
all the holes are pre-drilled makes for easy ziptie'in...
decently strong but its not actually bracing the robot in anyway.
Unread 27-01-2009, 23:45
We've used 1/16" sheet metal with a protective and antistatic paint coating. We're using polycarbonate at 1/16" and reinforced in some areas.
HDPE is fun to use and 1/4" will get heavy.
Dude just come over =(
We have so much polycarb!!
Unread 27-01-2009, 23:49
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
3/16" polycarb this year, we've used 1/2" plywood with great success before.
"we don't build robots, we build people"
Unread 27-01-2009, 23:58
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
We used to use 1/32 Aluminum 3000 series sheets. This year we are talking a half inch piece of wood and CNC wire channels and the placement of components into it. Also we are engraving our key of electronic wires into it. Love having a Router and Mill.
R.C.
MadTown Robotics Team 1323
Unread 28-01-2009, 08:05
We use perforated aluminum sheet. It is stretched across the base of the robot and riveted in place. Components are tywrapped to the sheet so that any changes or swap of defective components can be easily performed with a minimum of tools, no dropped screws or other conductive hardware and the ability to see everything from both sides of the mounting platform.
Unread 28-01-2009, 08:16
Jared Russell's Avatar
Taking a year (mostly) off
We have generally used Lexan (polycarbonate) in the past, but this season we are using plywood. Both work just fine.
Masonite might be overkill.
Unread 28-01-2009, 08:20
RyanN's Avatar
RyanN
Watch out for the cRIO this year. I believe it's grounded, so you would need to insulate it from the aluminum in some way. I know Lowes sells nylon bolts that may do the trick. Of course, you'll need something between the cRIO and the aluminum sheet as well.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 28-01-2009, 08:29
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
06 - polycarb.
07 - aluminum. Never again will we have a conductive backplane.
08 - Gatorboard (foam laminated between post-card stock) previous years, polycarb this year. Breakable if mounted vertically. Nylon screws and nuts ($5.50 from mcmaster for 100).
09 - Polycarb. Nylon screws and nuts.
Metal Electrical Board aaeamdar Rules/Strategy 3 16-02-2008 20:49
Team 384's Electrical Board!!! sayso_411 Robot Showcase 11 14-02-2008 21:51
pic: 469 Electrical Board Don Wright Extra Discussion 11 12-03-2007 21:17
pic: 494 Electrical Board. want2modmygt Robot Showcase 2 12-02-2006 14:28
Name our Electrical Board! Excelsior Chit-Chat 17 19-01-2006 11:14
