Go to Post you know you are addicted to first when u crave sprockets for breakfast! - Jones571 [more]
Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Unread 27-01-2009, 23:14
Scott Hill Scott Hill is offline
FRC #1625 (Winnovation)
Scott Hill is a splendid one to beholdScott Hill is a splendid one to beholdScott Hill is a splendid one to beholdScott Hill is a splendid one to beholdScott Hill is a splendid one to beholdScott Hill is a splendid one to beholdScott Hill is a splendid one to behold
pic: Robot Bumpers
Unread 27-01-2009, 23:17
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: pic: Robot Bumpers
Well, we might as well have at it again.
I'll start by saying I don't believe this is legal, because corners A and B are not protected on both sides of the corner. I think it is made very clear by the GDC in their response in this Q/A forum post http://forums.usfirst.org/showthread.php?t=10933
In the above picture, I see two corners, A and B, each with one side that does not satisfy the "Both sides of the corner must be protected by BUMPER segments" ruling.
Unread 27-01-2009, 23:23
CraigHickman
Posts: n/a
To play devil's advocate, the rules (numbers of which I forget) about trailer hitch mounting forbid bumpers in the pivot area. Which rules trumps which?
Unread 27-01-2009, 23:26
Rizner's Avatar
Rizner Rizner is offline
FRC #2425
Rizner has a spectacular aura aboutRizner has a spectacular aura about
I think they want both followed. It is to my understanding that you must have bumpers on your back segment (to cover the corners), and those bumpers must not be in the pivot area.
I think that means that you need room on the back for 6" on each side of the pivot area.
Please, correct me if I'm wrong.
-Rizner
Unread 27-01-2009, 23:29
CraigHickman
Posts: n/a
-Rizner
Again playing devil's advocate (my opinion here is irrelevant), This design follows the intent of all bumper rules. It is well protected from all hits, while still allowing mobility of the trailer. If the bumper rule intent isn't to keep robots protected, then what IS it for? I mean honestly, the rules on bumpers this year are ridiculous to make me reconsider doing next year, as I know they can only follow the same path they've been following the recent years.
Unread 27-01-2009, 23:30
Aren_Hill's Avatar
Build Nifty Things
this pic was posted to explain in the current thread running of "is this corner considered protected" discussion goes there
A guy who likes robots.
Unread 27-01-2009, 23:39
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
I call this configuration LEGAL within the rules set forth in the competition manual. It clearly meets the intent and follows all published rules.
Corners A and B do not have to be protected on both sides of the corners because a Q/A response is not a rule.
BTW, I love this topic. We could debate this for years and you could make a good argument either way.
Unread 27-01-2009, 23:46
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Yeah, it could go on forever...
I think the Q&A response gives the GDC's meaning of "protected" as having BUMPERS on both sides of each corner.
I sure hope they get that into the rules, if that's their intent.
Unread 28-01-2009, 00:01
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
The original intent of this design was to allow the robot to turn tight on the trailer.
This is all in vein. The trailer that everybody built has a ¾ pipe that the hitch assembly allows the trailer tung to move up to 90 degrees. The competition trailer is different and has a 1 inch x 1 inch square pipe with a short pin that is inserted and secured. If you turn the trailer more than 30 degrees the square pipe of the trailer hits the trailer hitch of the robot which is a violation. A turn of 35 degrees gets you to a contact point of a normal square cornered robot. There is no advantage to gain the 5 degrees.
Although I like this year’s game they have tied up the design rules so tight that everybody’s robot is going to be very similar. They are chocking our creative design ideas with every turn. I miss the day’s when you could make it open up as big as you want and did not have to worry about bumpers.
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Unread 28-01-2009, 00:11
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Yes, the Q&A's are not official rules, but they exist to provide guidance for referees, inspectors and other officials when making rulings. To ignore a fairly clear and unambiguous Q&A would be pretty irresponsible. I've seen teams try and pull the "Q&A's aren't real rules" card at events, and it has never worked. One incident sticks out in my mind, where a team directly asked if they could drill lightening holes in their flag holder. The GDC replied with a very firm "No". This same team tried to use a lightened flag holder at events, and was turned back pretty promptly. Don't be that team. Building a robot that directly goes against a ruling in the Q&A will only end up wasting both the time of your team and the inspectors.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 28-01-2009, 00:22
If you want to see this discussed with reference to the Q&A go the "Is this corner protected" thread. The image was created to supplement my latest response.
Scott
Edit: I do not believe this configuration is in conflict with the Q&A GDC responses.
Unread 28-01-2009, 00:42
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Furthermore, we had a team do the same, then came back the next day with duct tape covering the entire PVC holder.
That was a "No-no."
Unread 28-01-2009, 07:16
Jared Russell's Avatar
Taking a year (mostly) off
There is no way (in my opinion) that this is a legal frame. The GDC has clearly and repeatedly stated through the Q&A that all bumper perimeter corners must be protected on both sides by a bumper segment of at least 6 inches. You are taking an enormous risk if you play the "it's not a rule" card.
Rules don't trump other rules, ALL rules must be obeyed. There is no way that the configuration shown meets all of the rules set forth by the GDC. We went through this same process with concave openings on the front of the machine (see this), and the GDC was firm in reaffirming that the rules are the rules.
Hopefully the GDC responds to your question clearly and unambiguously, but we've been snakebitten by the letter of the law before. Good luck!
Unread 28-01-2009, 07:48
Triple B Triple B is offline
all hail Passmore
AKA: Mike D is FTG too
None #0233 (The Pink Team)
Triple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant future
Unhappy Re: pic: Robot Bumpers
I must agree, It sounds to me as if they want eveyone to just use the rectangular kit bot chassis, a drawing could be posted showing the only legal bumper configuration, and then we could all just slap some team numbers on and go. I am NOT a fan of bumpers.
Mike d
See Ya
Unread 28-01-2009, 08:11
Mike d
Agree totally. The rules this year legislated out a LOT of room for innovation. But FIRST is made up of smart folks; I think (and hope) that next season a little bit more leeway will be given back to us.
pic: PD-1345's 2008 robot without bumpers Arefin Bari Robot Showcase 2 23-02-2008 23:44
pic: Finished 1024 2008 Robot (without black bumpers to show detail) Qbranch Extra Discussion 5 19-02-2008 20:51
pic: Purple Bumpers - 418 leeweek Extra Discussion 5 05-04-2007 00:12
pic: RC 1736 bumpers bam_415 Extra Discussion 5 27-02-2007 20:12
Robot bumpers EricLeifermann Technical Discussion 15 12-01-2007 02:18
