Go to Post This thread should surface like this before every new season. It is motivating and inspiring. And jawdropping. - JaneYoung [more]
Unread 27-01-2009, 21:48
ijk90825 ijk90825 is offline
FRC #3017
ijk90825 is an unknown quantity at this point
Camera problem
Our camera works when it's connected to the router with wire, but when it's connected to cRIO wirelessly, it doesn't work
We assume that it doesn't work with cRIO not the IP problem or other wireless problem, anyone have same problem like us? Or anyone know how to fix it?
Tyvm
Unread 28-01-2009, 01:35
Re: Camera problem
The camera is supposed to be connected (using the orange crossover cable) to the second ethernet port of the cRIO. When it is plugged in that way, your programming computer will not be able to communicate with it. The robot project templates to use as a starting point for your code will transmit the image to a dashboard program on your computer so you can see what the camera sees.
You should only connect the camera through the router if you are planning to use the Vision Assistant program (you will have to change your computer's IP address to the 192.168.0.anything-but-90 address).
Camera Problem ta1234 Programming 1 29-01-2007 09:38
Camera tracking problem Windward Programming 2 15-01-2007 17:59
Camera Problem Solved Scott Shaw 237 Programming 0 12-02-2005 10:07
camera problem miscar Programming 2 23-01-2005 12:06
Camera Problem n_0163 Electrical 3 14-01-2005 21:10
