Go to Post My advice is anytime your intuition tells you something, double check it with physics. - tennispro9911 [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 27-01-2009, 22:10
neoshaakti's Avatar
neoshaakti neoshaakti is offline
FRC #2554 (WarHawks)
neoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to behold
Send a message via AIM to neoshaakti
Extruded Aluminum Fastners!
Hey all our team really needs series 20 extruded aluminum fastners ASAP. Do you know nay suppliers who can ship same day? Thank you, I appreciate your help.
Unread 27-01-2009, 22:14
Re: Extruded Aluminum Fastners!
Check McMaster. They ship pretty fast. Just pretty fast--same day or next day if it's late enough.
Unread 27-01-2009, 22:20
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Since your in NJ, you might want to contact Team 11. They use 80/20 a lot. They might be able to help or give you some. If you want to contact someone on the team, email or im me.
R.C.
MadTown Robotics Team 1323
Unread 27-01-2009, 22:23
Lol
I love how you market our team.
In any case, I've been in contact with Neel since like last summer...we know of each others teams very well. Neel just check McMaster. As Eric said they are very good with shipping.
Unread 27-01-2009, 23:13
neoshaakti's Avatar
hmm, Im at a loss of where to start looking on mcmaster...there seems to be 10000 different fastners on mcmaster...
I think its on page 17 of this : http://download.8020inc.net/PDF/T-Sl..._Section_2.pdf
btw, we're using 20-4040 extrude
Unread 27-01-2009, 23:35
You mean the one that looks like a used staple correct? Yea we have some but shipping from us would probably be the same...unless you wanna drive down?
Unread 27-01-2009, 23:48
neoshaakti's Avatar
yea they look like bent staples, does anyone know what those clips are called??
Unread 28-01-2009, 00:44
novamx3 novamx3 is offline
FRC #2502
novamx3 is a splendid one to beholdnovamx3 is a splendid one to beholdnovamx3 is a splendid one to beholdnovamx3 is a splendid one to beholdnovamx3 is a splendid one to beholdnovamx3 is a splendid one to beholdnovamx3 is a splendid one to beholdnovamx3 is a splendid one to behold
They are called "end fasteners"
Part numbers are 3381 for ones with the 1/4-20 screw included.
3378 with no screw.
Those are 80/20 part numbers not Mcmaster
I suggest calling your local 80/20 distributor and support your local economy... Forget McMaster. I work with the local distributor in Minneapolis.
www.8020.net will help you find a distributor in your area.
Hope that helps...
Ian
Unread 28-01-2009, 06:19
Brian C's Avatar
Brian C Brian C is offline
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
You can also check with MSC. Do a search using "aluminum extrusion" the 80/20 stuff comes up within the first few items. They usually ship same day if you order before 1:00PM. Where you're located should be next day delivery with normal ground shipping. They have warehousing in the tri-sate (NY) area.
2017 Season; Game Announcer at
SBPLI Long Island Regional
[OCCRA]: extruded aluminum reposted bernieseaholm OCCRA Q&A 1 20-09-2007 11:35
[OCCRA]: extruded aluminum bernieseaholm OCCRA Q&A 1 19-09-2007 21:04
80/20 Extruded Aluminum MTA Gearheads General Forum 8 20-01-2007 19:10
T-Slot extruded aluminum blue_crew Technical Discussion 18 29-01-2006 13:05
Mini extruded aluminum Ravi U Technical Discussion 7 17-01-2004 02:12
