#8
Re: cRIO buzzing
The fact that you were able to run the battery down so low that the boost converter started to dropout means that the Power Distribution is doing EXACTLY what was intended - ie successfully power the cRIO and wireless adapter until the battery starts sagging < 6V. I'd consider your observations to indicate an excellent test of the PD ... and it easily passed.
Thanks for the feedback! I'll bet you'll be more careful about keeping your batteries topped off from now on ![]() Russ |
| fried cRio??? | morganh2550 | FRC Control System | 13 | 24-01-2009 21:11 |
| cRIO v7 fails | Peter H | FRC Control System | 7 | 18-01-2009 14:26 |
| cRIO Problems | computerboi1503 | C/C++ | 7 | 11-01-2009 09:35 |
| cRIO Problem | Pneumaticsman | NI LabVIEW | 8 | 10-01-2009 11:59 |
| cRIO feedback | Maxpower57 | C/C++ | 2 | 08-01-2009 19:06 |
