Go to Post Having 75% of the drive train without direct connection to the transmission would make me a bit queasy, but then again, I'm not Winnovative. - Taylor [more]
Unread 28-01-2009, 12:22
run the trap!!!
Team Role: Human Player
Re: pic: Frame Design
Just a suggestion if amateurs are welding it:
Cut out some little 1/8" thick gusset plates and weld them on all the joints. Not only will this be far stronger than butt-welding, but it will also be MUCH easier. Butt-welding 1/16" tube is very difficult, without considerable practice you'll get lots of burn-through (or if your current is set too low) you won't get enough penetration to hold the weld.
We used to have a sponsor weld our frame, and he always had trouble with the butt-welds. After we added gussets... even the kids could do it.
-Philip J. Fry
pic: 48 Frame Travis Hoffman Extra Discussion 6 26-01-2008 23:14
pic: Frame is falconmaster Extra Discussion 1 17-01-2008 23:11
pic: Concept Frame armoredvehicle Extra Discussion 6 16-12-2007 20:55
pic: 1123 Frame ShadowKnight Extra Discussion 8 21-01-2005 09:20
pic: 1305 Frame design with trannies CD47-Bot Robot Showcase 19 25-09-2004 01:13
