Go to Post Every team should have a rule about not shouting "ROBOT!" when transporting a robot around the pits/arena. - frasnow [more]
Unread 26-01-2009, 19:47
markulrich's Avatar
markulrich markulrich is offline
Head Captain and LabVIEW Programmer
FRC #2129 (Ultraviolet)
markulrich has a spectacular aura aboutmarkulrich has a spectacular aura about
Multiple Targets in "LabVIEW Sample two-color target tracking code"
Hey all,
My team doesn't have 2 vision targets and I couldn't tell by looking at the code; what happens if you have more than 1 distinct vision targets in front of the camera? (Does it return a rectangle covering both of them, or does it lock on to the bigger one, will the area percent include both, what if the 2 are switched, etc.)
Thanks!
Unread 26-01-2009, 21:19
Re: Multiple Targets in "LabVIEW Sample two-color target tracking code"
The way the example code was written, it will sort by size and then test the particles one at a time. If they overlap, the camera will likely likely see them as one, otherwise it will describe the largest.
If you'd like to get info on more than one, you can change the example to keep looping until you find as many as you like.
Greg McKaskle
Unread 27-01-2009, 15:15
markulrich's Avatar
So if the targets weren't overlapping it would just select the larger target?
Unread 27-01-2009, 16:09
It will describe the largest based upon the primary color threshold.
Greg McKaskle
Unread 28-01-2009, 12:44
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
Originally Posted by markulrich View Post
Hey all,
My team doesn't have 2 vision targets ...
Thanks!
A little trick I did, cut some small squares from the fabrics and hold those closer to the lens. Gives you something to work with anyway.
jc
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 28-01-2009, 12:55
You can see a video demonstration of the multi-target tracking in the middle of this video: http://www.youtube.com/watch?v=15nqy7hKixA
Unread 29-01-2009, 09:26
markulrich's Avatar
Very cool video! I saw that it was always able to pick the "enemy" target - what if you have 2 enemy targets infront, I assume it picks the larger one? (It doesn't just think there is a huge target and aim between them?)
Unread 29-01-2009, 11:52
At 1:15 there are two enemy targets, and it went for the larger one. It should be impossible to get 2 targets that are the same size and blend together, because of the dimensions of the trailer. And, if you get one trailer in the perfect position behind a trailer so they blend, it's unlikely to stay that way for very long.
Two Color Tracking Demo Bharat Nain Programming 43 25-01-2009 18:58
Two color tracking problem nadavsen2 Programming 3 19-01-2009 14:44
Camera locked in "tracking", but not tracking geeknerd99 Programming 1 18-02-2007 22:47
Green target has to "warm up"? Eldarion Programming 14 27-01-2006 12:52
Camera never finds target, stays at "Searching..." Mike Programming 12 22-01-2006 12:47
