Go to Post Our team is using a video camera with frame-by-frame analysis to figure out all the characteristics of the foam ball. If the Boeing engineer says it's possible, I'm going to believe him. - sciencenerd [more]
Unread 28-01-2009, 15:29
lingomaniac88 lingomaniac88 is offline
FRC #1554
lingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud of
Building WindRiver Code?
I am trying to build my code in WindRiver, and I'm having some problems.
When I select Project->Build Project, here's what I get:
Build Started in Project 'DefaultRobot': 2009-01-28 15:21:54
Generation of makefiles started.
Folder "/OriginalDefaultCode" used in build target "OriginalDefaultCode" not found.
Build Finished in Project 'DefaultRobot': 2009-01-28 15:21:54 (Elapsed Time: 00:00)
The bottom of the window reads:
"Build succeeded for project DefaultRobot."
However, when I did a search, the only .out files I found were last modified in 2005 or earlier, clearly not what I'm looking for. What's going on?
"It is common sense to take a method and try it. If it fails, admit it frankly and try another. But above all, try something."
-- Franklin Delano Roosevelt.
Unread 28-01-2009, 15:39
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
Re: Building WindRiver Code?
Try closing and reopening the project, followed by doing a rebuild -- not a build.
Unread 28-01-2009, 15:48
FRC #1554
I tried doing that, and I got the same thing.
I think the problem involves this line:
I looked up how to change the build target, but the instructions in WindRiver don't seem to be consistent with the actual software. Is it possible to change the build target?
Unread 28-01-2009, 16:05
gvarndell's Avatar
Software Engineer
FRC #1629 (GaCo)
Team Role: Parent
You can change certain aspects of a build target, but it's probably easier to delete the faulty one and create a new one.
If you want to export your project to a zip file and post it here, I'll try to take a look at it -- but I won't be able to do that before late this evening.
Unread 28-01-2009, 17:09
FRC #1554
It's okay, I got the code to build. I just changed the target location for the .out file and it compiled correctly. Thanks for your help.
Windriver does not finish building unobtainium-42 C/C++ 8 26-10-2009 13:33
Windriver downloading code problems. HUmar104 C/C++ 4 25-01-2009 20:53
warning when "Building" Code nick_champ_2 NI LabVIEW 2 25-01-2009 11:18
Problem debugging code with WindRiver LinuxMercedes Programming 3 07-01-2009 11:10
Trouble building code Omni Programming 2 30-01-2008 18:33
