Go to Post 254 isn't just good at building their robot. They're also good at taking pictures of it. - Chickenonastick [more]
Unread 28-01-2009, 17:11
eweathers eweathers is offline
None #1660
eweathers is an unknown quantity at this point
Exclamation How do I program a relay to turn on and off by pressing a button on the joystick?
Basically I want to program a relay connected to relay port 1 to go forward by pressing button 1 (trigger) and go reverse by pressing button 2 on the joystick.
Can anyone help me program this?
Thank you in advance.
Unread 28-01-2009, 19:32
Geekzilla201 Geekzilla201 is offline
Alumni/Volunteer
no team (Bob's Builders in Black)
Geekzilla201 is an unknown quantity at this point
Re: How do I program a relay to turn on and off by pressing a button on the joystick?
LabVIEW or WindRiver?
Computer Science House - Rochester Institute of Technology
Unread 28-01-2009, 22:14
Boydean's Avatar
Boydean Boydean is offline
The Blue Alliance
Boydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant future
Send a message via AIM to Boydean
First things first. What do you really want to do. Do you want button 1 to make it forward without it being pressed down, and then backward when button 2 is pressed...so all its doing is changing the state. Or do you want it to go one way while you press button 1 and the other way while you press button 2. And its natural would be stopped.
Unread 28-01-2009, 22:29
AndrewN's Avatar
AndrewN AndrewN is offline
it's alive!
AKA: Andrew Nicholson
FRC #1778 (Chill Out)
AndrewN is just really niceAndrewN is just really niceAndrewN is just really niceAndrewN is just really niceAndrewN is just really nice
Try something like this example in the Basic Framework:
http://www.chiefdelphi.com/forums/at...d=123319909 8
The "Off", "Forward", "Reverse" are constants created from the input to the relay "Set" VI.
The Up/Down arrows on the while loop are "Shift Registers" created using the menu on the while loop border. These are used to contain the current setting of the relay.
The T/F selectors are on the Programming Comparison Palette. These allow you to select the old value or the new one based off the buttons.
The buttons are obtained using the cluster "unbundle by name" function.
There is no button to turn the relay off ... you'll have to extend the example.
Don't forget the other cases in the main loop. The example is not complete.
Andrew Nicholson
2011 FRC Robot Inspector (Seattle, Portland)
Mentor FRC 1778 "Chill Out", FTC 3018, 3940 "Hawks", 4434 "Heat Misers"
"Everything should be made as simple as possible, but no simpler."
Unread 28-01-2009, 22:34
TotalChaos's Avatar
TotalChaos TotalChaos is offline
AKA: Austin
FRC #2837 (Freebird Robotics)
TotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud of
Send a message via MSN to TotalChaos
First off, welcome to ChiefDelphi!
Second, I've seen this exact question asked a couple of times now. I have and example VI that is documented and shows how to do this. You can download it from my post in THIS THREAD.
Good luck!
- Austin
The 39th Aero Squadron - Team 39! (Visit our website!)
Team Role: 3 Years as Driver - College Student/Mentor!
Freebird Robotics - On a 1 year hiatus! (Visit our website!)
Arizona 2009: Semifinalists! (69 and 498), Delphi "Driving Tomorrow's Technology" Award
How do I Link a (group of) Joystick button(s) to a motor? CardcaptorRLH85 C/C++ 2 22-01-2009 23:23
How to program relay in labVIEW? frcchile NI LabVIEW 1 16-01-2009 13:36
Program a motor to turn on and off every other second..... programmr Programming 15 29-01-2008 10:14
How fast does the Solenoids turn on and off? Generalx5 Robotics Education and Curriculum 2 26-01-2007 01:09
Anyone know how fast the Solenoids on the MINI RC can turn on and off? Generalx5 Control System 1 06-01-2007 07:39
