Go to Post I don't care if you use hot dogs for wheels. If you're scoring points, and you fit the strategy, it's fine. - evanperryg [more]
Unread 26-01-2009, 17:03
boehmz boehmz is offline
FRC #1730
boehmz is on a distinguished road
Weird Things that Happen to me with Max
2 Main things for now:
1. Sometimes when I open a file, I cannot undo anything. I have the undo limits set to around 50, but it won't let me use ctrl + z or the button. It is also empty when I right click on it.
2. I always have trouble animating specific vertexes. When I have an object's motion already animated, I apply edit poly and form the vertexes how I want them. Sometimes the entire scene will only show the latest changes I made, even tho I have applied them at different times. Example: A box is moving across the screen. I want it to go from a simple box at frame 0 to one with a point on top at frame 100. When I set the key at frame 100, the point will already be there at frame 0. I redo everything and the second or third time it works. What exactly should I be doing to make this less painful?
Thanks for any help!
Unread 26-01-2009, 17:32
Church's Avatar
Church Church is offline
FRC #2180 (Zero Gravity)
Church is a jewel in the roughChurch is a jewel in the roughChurch is a jewel in the roughChurch is a jewel in the rough
Re: Weird Things that Happen to me with Max
The only think I can suggest for the animation problem is to double check the whether you have it set to "set frame" or "auto key." I'm not really a pro so I'm sorry if that's not much help!
"If the dog didn't stop to pee, it wouldn't have been hit by the tree." -- Mr. McGowan
Church? No, it's not a Red vs Blue reference. It's my name.
Webcomic about FIRST! The FIRST Team
Unread 26-01-2009, 19:20
Rizner's Avatar
Rizner Rizner is offline
FRC #2425
Rizner has a spectacular aura aboutRizner has a spectacular aura about
Yeah, he is right. Make sure before you do anything that if you want it the way it is at frame zero, go to frame zero and set the key there.
Also, I'm pretty sure that after a file has been saved and closed (maybe after another file opens, not sure) that the undo buttons aren't saved in the memory any more. I would suggest saving multiple files if you think going back steps might be needed in the future (Scene1_v1; Scene1_v2; ...)
Unread 26-01-2009, 20:27
BuddyB309's Avatar
BuddyB309 BuddyB309 is offline
I freaking love animating!!
AKA: Peter Casey
FRC #1625 (Winnovation)
Team Role: Animator
BuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond repute
Send a message via AIM to BuddyB309
ok, take a step back, let me get this strait. Your animating the vertexes in edit poly? That would be your problem. Don't animate in edit poly. Skin your object with bones or dummy objects and animate it that way. Animating with edit poly is so incredibly buggy. My goodness, I had models explode on me.
A.K.A Llama
check out my latest animations Appliance Night Out, Infant Intolerable, Fishing Like a Loony Tune, VVV Roadside Assistance
Life? I have a life. It is sitting at my computer and Animating. AND DRAWING!!! WEEEEEEE!!!!
Unread 27-01-2009, 15:13
Jreed129's Avatar
Jreed129 Jreed129 is offline
animation mentor
AKA: Jeremy Reed
FRC #0103 (Cybersonics)
Jreed129 will become famous soon enough
One of our animators is having a different problem but I feel that this is a weird thing happening with max.
general information:
Program: 3ds max 2009 32 bit
Computer: 3Ghz, 3GB
I know that that information my not be in the problem
Anyway, in 3ds max the student is trying to rotate and object and it will rotate but the X,Y,Z coordinates do not match up. Max does not seem to be holding where the student is moving from, so when the student tries to go back to 0,0,0 Max sets the current location of the object as 0,0,0 and does not move it at all. if the student tries to enter coordinates the difference from 1,0,0 to 2,0,0 will be a turn of more then 90 degrees.
if anyone knows of a setting that may have been messed with that would cause this to happen we would be greatfully.
Unread 27-01-2009, 17:07
FRC #1730
I'm not sure about the rotation problem. The math person in me says that the units got changed to radians, but I'm not sure if that's even possible and even if it is, then highly unlikely.
It is good to know that it wasn't me who was screwing up while animating with edit poly. I don't understand what you mean by using bones. I switched to using FFD, which animates fine for now. If bones and skinning is the best could you care to give me a brief synopsis?
Unread 28-01-2009, 07:56
BuddyB309's Avatar
AKA: Peter Casey
Team Role: Animator
I cant tell you your best approach without seeing your object. If you post a picture of what you are animating then I can tell you.
Reset your Xform, which is located in the utilities tab. (the hammer) Select your object then select the button that says, Reset Xform.
A.K.A Llama
Unread 28-01-2009, 18:24
FRC #1730
How would I animate my leaf man character? He's technically an extruded line. I was going to move the outermost vertexes around and have them act like hands. Moving them sometimes causes the extrude not to fill in the middle. Should I just add hands or is there a way i can do this?
http://img220.imageshack.us/my.php?image=leafmannf1.png
Unread 28-01-2009, 19:08
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
FRC #1716 (Redbird Robotics)
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
#1 as soon as you save something, close it, and then reopen it another time, you are unable to "undo" what you have did before you saved by clicking the undo button, you will have to physically modify the object you are creating.
#2 remember that if you are using set key, you will need to set a key at frame one before you place a key at frame 100. But if you are using auto key, you should be able to just set a key at frame 100 and it will automatically set a Key at Zero!
Home it helps!!
-Team 1716
RTFM -Read The First Manual
You already are who you are, I may be able to show you a fancy trick or two, but the term "Better" is relative to the potential you already have.
Take a look at my website/Blog!
Unread 29-01-2009, 03:26
fireball3004's Avatar
fireball3004 fireball3004 is offline
James Davis
AKA: James Davis
FRC #2090 (Punahou Robotics)
Team Role: Animator
fireball3004 is an unknown quantity at this point
Send a message via AIM to fireball3004
In reference to your leaf character...
Your charaacter is 2 dimensional? Well you can always attach your character to a bunch of dummy obects... I simply have never tried rigging a 2D object.
May I suggest warping a thin box and pulling out a stem ect to make a leaf, and then maybe giving him arms, legs, eyes and maybe a mouth? Although you don't need to give him any of those body parts in specific, it seems it would be prettier and maybe even a bit easier.
Newbies away
Unread 29-01-2009, 09:51
BuddyB309's Avatar
AKA: Peter Casey
Team Role: Animator
You did not cut any polygons into the leaf, I'm pretty sure you just made the leaf with the spline then put the extrude modifier on it. What you need to do is put edit poly modifier on also then use the cut tool to break up your polygons. Make sure all your polygons have only four sides to them otherwise you will run into trouble.
Then rig with bones and apply the skin modifier. Set the weights of the vertices's and then you can animate the hands. If you want to an easier route. You can just apply the bend modifier but his facial features wont stay on the leaf. This is solved by making dummy objects and using the attachment constraint on the dummies to the body of the leaf. Pick a face closets to the object that how are going to link to the dummy using the motion tab. (the one with the little wheel) Then link the separate objects (facial features) to the dummies.
thank you for including a picture.
A.K.A Llama
Amazing Things Happen Video, Do you know where to get it? Weightmn General Forum 10 11-12-2007 12:47
weird question that came up today Andy L Technical Discussion 14 31-03-2007 17:57
What are some things that you associate with first or the FIRST regionals? A. Snodgrass Chit-Chat 12 24-02-2003 02:13
That Is Awesome!!! How Did It Happen??? Elgin Clock CD Forum Support 12 01-12-2002 17:43
Any funny things happen during the season this year? Greg Perkins General Forum 13 06-03-2002 01:35
