Go to Post Ok, according to this, I am a hacker...Now will someone please come fix my computer??? - Beth Sweet [more]
Unread 28-01-2009, 18:18
Betty_Krocker Betty_Krocker is offline
Fabricator/Hacker/Comic Relief
AKA: Michael
FRC #2028 (Phantom Robotics)
Betty_Krocker is an unknown quantity at this point
Send a message via AIM to Betty_Krocker Send a message via Yahoo to Betty_Krocker
GLOBE GEARBOX [edited]
Does any one know how to seperate the globe motor from the gearbox...
This has baffled the Game Mech Dept for awhile now, and its getting a little late, so some of the members just want to throw it at a wall and see what happens...
Anyone who can help
Thanks
"Measure once, cut twice... wait... what?"
"Two things needed to build a robot.. WD40 for the things that don't move but should, and Duct tape for the things that move but shouldn't"
Unread 28-01-2009, 18:34
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Re: GLOBE GEARBOX [edited]
Anyone who can help
Thanks
I believe it involves getting a punch and tapping in the little roll pins around the gearbox/motor interface. Tapping them inward will allow you to remove the motor. After this, take out the roll pins, do your mods, reassemble the components, then tap the roll pins back in.
Unread 28-01-2009, 18:36
Brandon Holley's Avatar
Did this the other day.
Remove snap ring on shaft.
Tap roll pins INTO gearbox.
Use chisel/flathead screwdriver to GENTLY tap the gearbox apart from the motor.
The end.
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 28-01-2009, 18:38
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
There are three spiral spring pins inserted into holes around the circumference of the gearbox, near to the motor. Each is about Ø0.093 in, and 0.188 in long, if I remember correctly. Using a small punch (or even the back end of a small drill bit in a drill press), press each of the pins into the gearbox. It should then come off easily, and the shaft and planet carriers will come out.
You're probably not going to like the motor pinion that you find inside, though. I'm not sure exactly what it is, but it's got very small teeth.
Unread 29-01-2009, 01:35
JHSmentor's Avatar
JHSmentor JHSmentor is offline
AKA: Bryan Molloseau
FRC #3210 (Falcons)
JHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to all
you don't actually need to remove the c-clip on the output shaft when removing the gearbox - just tap in the set pins on the sides and pull the gearbox off. The pins push in quite a ways - over 1/8" for sure.
we just put one back together that was taken apart earlier - not too difficult once you figure it out.
Unread 31-01-2009, 19:36
Kevin Ray's Avatar
Kevin Ray Kevin Ray is offline
None #0329 (Raiders)
Kevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to behold
What do you plan on doing? Are you going to remove the last stage? Doing so gets the speed up to 450 rpms.
_____________________________________________
Last words before magic smoke appears: "There, that oughta work!"
2016 Utah Regional- Engineering Inspiration
2016 Utah Regional- Dean's List Semi-Finalist- Ed O'Connor
2016 Utah Regional- Dean's List Semi-Finalist- Emily Ferrari
2016 Utah Regional- 3rd seed
2016 SBPLI Regional- Finalist, 6th seed
2016 SBPLI Regional- Gracious Professionalism Award
Globe Motors joesmomh00haha Technical Discussion 1 14-02-2008 10:36
Globe Motors Guy_E Motors 10 21-01-2007 16:53
Offseason gearbox project... maybe this gearbox has helical gears? Travis Covington Technical Discussion 17 05-06-2006 11:48
Globe Motor archiver 2000 4 24-06-2002 00:15
Globe Motor archiver 2000 0 24-06-2002 00:15
