Go to Post A dedicated team is a happy team. - sgreco [more]
Unread 28-01-2009, 21:29
sparrowkc sparrowkc is offline
AKA: Mark
FRC #1986 (Team Titanium)
sparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to behold
Signal wire gauge and color.
I'm pretty sure we can use 24 gauge wire for for hooking up a potentiometer. Do color requirements not apply to 5v sensor wire, or do I need to get some red black and white 24 AWG wire?
Unread 28-01-2009, 21:50
Jared Russell's Avatar
Taking a year (mostly) off
Re: Signal wire gauge and color.
R46:
<R46> All active Power Distribution Board branch circuit wiring with a constant polarity (i.e., except for relay module, speed controller, or sensor outputs) shall be color-coded as follows:
A. Use red, white, brown, or black with stripe wire for +24 Vdc, +12 Vdc and +5 Vdc connections.
B. Use black or blue wire for common (-) connections.
So for a pot, you will have common (black or blue), +VDC (red, white, brown, black w/stripe), and wiper (anything you please - but avoiding the same colors you used elsewhere is a good practice. Usually I use yellow or white for signal).
Unread 28-01-2009, 21:53
soccer_ghena's Avatar
soccer_ghena soccer_ghena is offline
FRC #0240
soccer_ghena is an unknown quantity at this point
• Connect the wiper to the input pin – Top row.
• Connect the other two pins to +5 and ground – Middle and bottom rows.
There is a thread about this.
http://www.chiefdelphi.com/forums/sh...oten tiometer
If that helps that is.
Unread 29-01-2009, 07:55
Sparrow,
Although there is no strict rule governing sensor color code, standard practice would make that recommendation. R46 above relates to power distribution as Abwehr pointed out and those colors may be used. A PWM cable makes a perfect connection medium for your application and will maintain a color code that both you and others can easily identify. Red for positive voltage, black for common and white for signal or in your case, pot wiper.
Unread 10-03-2010, 19:51
Rapt0r9's Avatar
Rapt0r9 Rapt0r9 is offline
AKA: Tyler
FRC #0747 (Flight Crew)
Rapt0r9 will become famous soon enoughRapt0r9 will become famous soon enough
Gauging can be light for sensors and signal devices. We've always followed the practice of using red for V+, black for GND, and white as a signal color.
PWMs are perfect for this as they give you the connector on the other end if you are connecting the device directly to an input.
BS Information Technology - NJIT (2009 - )
Team 869 (2004 - 2008, 2011 -), Team 1811 (2010), Team 869 (2009), Team 613 (2009 - 2010)
"Nothing in this life worth having comes easy."
Spike Relay Wire Gauge sparrowkc Electrical 7 12-02-2008 14:26
Wire gauge vs. current AdamHeard Electrical 7 09-11-2007 10:36
Wire Gauge Question Neghman Electrical 1 14-02-2004 19:56
Line sensor wire gauge questions Dinush Electrical 6 13-02-2004 18:41
11 Gauge Wire...where? Matt Krass Electrical 6 21-01-2003 10:17
