Go to Post When teams work together to design things rather than going it alone, you can really come up with magnificent machines. - JesseK [more]
Unread 28-01-2009, 21:52
piedmont piedmont is offline
FRC #3022
piedmont is an unknown quantity at this point
Front Bulldozer Bumpers
Hi, team 3022 here, we're a rookie team and we were wondering if there are any specific rules as to creating a small bulldozer in front of the bot to push the balls to the corners of the arena for the human players. Also, if there are specific rules, if its made out of bumper material and can be removed, is it considered part of the bumper itself, or is it part of the bot, because our bot has already met the maximum length and width it can be without the bumpers. Help us please
Unread 28-01-2009, 21:55
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Front Bulldozer Bumpers
You can find the FRC rules for this year at usfirst.org . Specifically, "The Robot" portion of the manual will have very specific instructions for the location, shape, and size of bumpers.
Though at this point in the season, if you haven't at least read the rules once, I think you may have bigger problems than just bumper design
Unread 28-01-2009, 21:59
FIXIT's Avatar
FIXIT FIXIT is offline
FRC #0120 (Red Dragons)
FIXIT is a jewel in the roughFIXIT is a jewel in the roughFIXIT is a jewel in the roughFIXIT is a jewel in the rough
If you are asking if you can push the balls with your bumper, I think the answer is YES. There are very specific bumper rules and you will need to be careful on what you plan to do with them. Do a search of this forum and read what others are saying. You might want to log in to the FIRST Q&A section and read up on other post.
Cleveland's Team - The Red Dragons
Youth Technology Academy ---Cuyahoga Community College
Unread 28-01-2009, 22:00
FRC #3022
I am aware of the specific details as to how the bumpers are placed on the bot, but that is not what I'm asking for . Im wondering if I were to place a protrusion in front of the bot in somewhat of a v shape in order to easily collect balls, would it be considered part of the bumper and whether there are rules as to how far they stick out or anything like that?
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Of particular note in the rules, note the BUMPER PERIMETER definition, and that nothing may extends past the bumper perimeter, ever.
Then note the definition of BUMPER, and note the restrictions on what you may modify about a bumper -- only the length and how they attach to the robot.
Then also note the game rule that says no matter what, the bumpers must be the only things that make contact with another team's trailer, which can affect how wide an 'open' spot is.
If your bulldozer can fit within these and other rulebook design constraints, you shouldn't have a problem.
GitHub
Unread 28-01-2009, 22:02
Jim E Jim E is offline
FRC #1523 (M.A.R.S.)
Jim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond repute
The bumper rules are confusing, but still make perfect sense.
If your bulldozer is on the robot perimeter with padding, the padding can be considered a BUMPER and can be removed from the robot weigh-in. You must follow the instructions for constructing the BUMPER though
If it is behind the robot perimeter, then it is considered part of the robot. You will also have to accomodate 6" on each side for a BUMPER to protect the outer perimeter corners.
I hope this clears it up for you.
Team MARS = 1.523 AU from the SUN!
Jim E.
Unread 29-01-2009, 16:14
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
<R17> "Wedge” ROBOTS are not permitted. ROBOTS shall be designed so that interaction with opposing ROBOTS results in pushing rather than tipping or lifting. Neither offensive nor defensive wedges are allowed. All parts of a ROBOT between zero and seven inches from the ground (the top of the BUMPER ZONE) that are used to push against or interact with an opposing ROBOT must be within 10 degrees of vertical. If a mechanism or an appendage (e.g. a harvester for retrieving GAME PIECES) becomes a wedge that interferes with other ROBOTS, penalties, disabling, or disqualification can occur depending on the severity of the infraction.
This is one of the only rules, I know of, that would prevent any type of plow, but many teams have tried to utilize a U shape design and I think that by sinking the plow in an inch or two you'll be allowed to have a plow like mechanism
Unread 29-01-2009, 16:22
ScottOliveira ScottOliveira is offline
FRC #3455 (Carpe Robotum)
ScottOliveira is just really niceScottOliveira is just really niceScottOliveira is just really niceScottOliveira is just really niceScottOliveira is just really nice
That rule is referring to degrees form the horizontal, i.e. an incline. It sounds like the original question is about a vertically angled protrusion, i.e. a 'corner'.
Unread 29-01-2009, 16:35
jamie_1930's Avatar
Team Role: Student
I wasn't sure if they wanted to go both in horizontally and vertically I figured putting it out there wouldn't hurt if it's not the right orientation
Unread 29-01-2009, 19:12
Rick Wagner's Avatar
Rick Wagner Rick Wagner is offline
FRC #3008 (Kalani Robotics)
Rick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to behold
The answer to your question is yes, you can have a v-shaped plow, but it must be behind your front bumpers, not in front of them. I say bumpers (plural) because putting a plow behind a single bumper would be illegal (because being v-shaped, the plow could not support the bumper its full length as required) and useless. Suppose the front of your robot is the long dimension for efficient herding. Then you would have a 6 inch bumper on the left, 26 inches of v-plow recessed into the robot in the center, and a 6 inch bumper on the right front.
pic: Cheesy front falconmaster Extra Discussion 7 17-01-2007 15:46
pic: front view Tim566 Extra Discussion 2 24-03-2006 23:03
Front, Left Motors quickie25 General Forum 2 19-02-2004 22:48
Up-Front money Wayne Doenges General Forum 12 02-08-2001 14:17
Front Page News!!!! Pamela General Forum 3 09-07-2001 10:17
