Go to Post However, because they're programmers they just redid the interpolation tables for our motors as opposed to actually fixing the bent shooter. - Nuwanda [more]
Unread 27-01-2009, 16:47
thoughtbubble thoughtbubble is offline
FRC #2143
thoughtbubble is an unknown quantity at this point
Re: Did anyone use all 4 CIM motors for the wheels
Quick Question in relation here, is the limit for the motor this year only apply to the cims? We checked the rules but didn't find anything there any thoughts?
Unread 27-01-2009, 20:07
Rick Wagner's Avatar
Rick Wagner Rick Wagner is offline
FRC #3008 (Kalani Robotics)
Rick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to behold
It's in the Robot rules. You may use only the motors in the kit plus two additional CIMs.
Unread 28-01-2009, 07:46
From Rev E...
<R51>
Motors specifically permitted on 2009 FRC ROBOTS include:
A.
All motors, actuators, and servos provided in the 2009 Kit Of Parts,
B.
An unlimited number of COTS servos with a maximum output torque of 55 oz-in and maximum rotational speed of 100 rpm at 6 Vdc (e.g. HITEC model HS-322HD or HS-325HB servos, as provided in the Kit Of Parts),
C.
An unlimited number of FIRST Tech Challenge (FTC) servos (HITEC HS-475HB servos),
D.
One or two additional 2-1/2” CIM motors (part #FR801-001 and/or M4-R0062-12) in addition to those provided in the Kit Of Parts. This means that up to four, and no more, 2-1/2” CIM motors can be used on the ROBOT.
E.
COTS motors used as one-to-one replacements (i.e. identical vendor and part number) for motors, actuators and servos provided in the 2009 Kit Of Parts that may have failed or become inoperable.
Emphasis mine.
Unread 28-01-2009, 23:02
tennisbeast29's Avatar
tennisbeast29 tennisbeast29 is offline
Soup Eater
AKA: Nina Rao
FRC #2191 (Fluxcore)
tennisbeast29 is an unknown quantity at this point
I don't want to use all 4 CIM motors because 1. we should use it for a shooter and 2. I think it would provide too much torque, although I havent done the calculations yet.
Do any teams do calculations first, later on, or not at all?
Unread 28-01-2009, 23:30
rogerlsmith's Avatar
rogerlsmith rogerlsmith is offline
Software Engineer
AKA: Roger Smith
FRC #3357 (COMETS)
rogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to behold
Team is 904 using 4 CIM motors in the drive-train. I just posted a picture of our configuration on my blog.
Roger Smith
Mentor - FRC Team 3357
COMETS - Creating Outstanding Minds, Embracing Technology & Science
Share FIRST videos, photos and experiences at FIRSTObjective.org
Unread 29-01-2009, 00:17
bmarick bmarick is offline
FRC #2374 (Crusader Bots)
bmarick is on a distinguished road
4 CIMS - Drive
2 globes - Steering
1 motor - feeder
4 pistons - 2 for hopper, 1 for elevator, 1 for launcher
Unread 29-01-2009, 00:26
We made very careful calculations for optimum speed and torque.
Unread 29-01-2009, 00:42
jph399's Avatar
jph399 jph399 is offline
Programming
FRC #2500 (Herobotics)
jph399 is an unknown quantity at this point
We're just stickin with 2 CIMS and 2 gearboxes.
"Think Outside the BUN"
"If it doesn't fit - Make it Fit"
Unread 29-01-2009, 08:49
Enigma's puzzle's Avatar
Enigma's puzzle Enigma's puzzle is offline
Strategery
AKA: Matt Brechting
FRC #2075 (Enigma)
Enigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to behold
We are using 4 cims on the drive train, it should be pretty interesting
Unread 29-01-2009, 12:39
It's true the CIMs provide plenty of power for the regolith surface, but we are using four because we have four wheel independent control, and we need to use four motors that are alike. We did some tests with a higher gear ratio, on the theory that we could control better with less torque, but found that the standard kit tuff-box gear ratio worked best.
Unread 29-01-2009, 13:07
Mr_I's Avatar
Mr_I Mr_I is offline
AKA: Tom Indelicato, 811 Moderator, Mentor, Parent, ...
FRC #0811 (Cardinals)
Mr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant future
We're using just 2 CIMS for the drivetrain; the lack of friction led us to believe that more would just cause wheel slippage, and there's no need to engage in a pushing match.
1 CIM for collector
1 CIM for storage
1 Keyang for turret
1 Barbie for thrower
Still room for more ...
(Picture coming soon)
"It's NOT Just A Robot Thing!"
Unread 29-01-2009, 13:11
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We're pretending our FP motor is from a Power Wheels F-150 truck, rather than a Barbiemobile.
Unread 06-02-2009, 21:30
Shira Shira is offline
FRC #1836
Shira is an unknown quantity at this point
Team 1836:
4 CIMs for the wheels
1 globe for the conveyor belt
1 globe for the shooter
Two fisher price for lifting balls vertically
Keyang or Denso (not sure yet) for a roller at the entrance of the bot
Unread 06-02-2009, 21:36
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
2 cims for the drivetrain
1 keyang for the "thresher"
1 denso for turret
1 cim for harvester
1 cim for shooter
7 motors! more than we've ever used before
no pnuematics too
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 06-02-2009, 21:43
Originally Posted by Alan Anderson View Post
We're not even using two CIM motors for the wheels.
Indiana, huh? Shooting out supersonic streams of corn oil using the compressor?
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
[FVC]: Curiosity: Did anyone use the aluminum parts? Billfred FIRST Tech Challenge 6 29-04-2007 17:26
2006: Did anyone use the Mabuchi motor? Billfred Motors 18 28-04-2006 21:44
How did you use the FP motors? Validius Motors 25 02-03-2005 01:30
Can anyone confirm that the CIM and Drill motors are the same as last year? Jeremy Technical Discussion 2 12-01-2004 21:54
