Go to Post Don't give up on others. I believe in killing grumps with a smile! - maltz1881 [more]
Unread 29-01-2009, 09:50
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
pic: Team 383 teaser
Unread 29-01-2009, 09:51
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
Team Role: Driver
RMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to behold
Send a message via AIM to RMS11
Re: pic: Team 383 teaser
Spiral from the bottom looking up???
2009 Peachtree Regional Champs
2009 Palmetto Regional Champs
2008 Peachtree Rookie All Star and Rookie Highest Seed
Unread 29-01-2009, 09:52
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
I'm thinking it's an intake roller with pneumatic tubes as "fingers", similar to 842's design. That's one heckofa picture though, it could be anything!
Unread 29-01-2009, 09:53
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Its the inside of an intake roller with pneumatic tubing stuck into it.
Mentor 2415
Unread 29-01-2009, 09:54
Greg Peshek Greg Peshek is offline
FLL #2054
Greg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to all
Reminds me of the inside of our ball collector with the ends of pneumatic tubing (or some other tubing), glued into the PVC. I would imagine this would be the inside of the tube with the cut off ends of the tubing barely sticking into the inside of the PVC so you can fit a shaft through the middle. That could be off, but it looks a lot like the ball collector I was just making.
-Greg
Unread 29-01-2009, 10:05
A_Reed's Avatar
A_Reed A_Reed is offline
Lead Design Mentor
AKA: Adam Reed
FRC #0048 (Delphi E.L.I.T.E)
A_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to behold
...Solarized in Photoshop, you can tell by the white lettering on one of the pieces of pneumatic tubing about half way up.
Unread 29-01-2009, 11:15
Woody1458's Avatar
Woody1458 Woody1458 is offline
AKA: Woody Jansen
FRC #1458 (Danvillans)
Woody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to behold
Send a message via AIM to Woody1458
http://img48.imageshack.us/img48/9659/teasernegtm1.jpg
With negativity removed.
Also by counting the tubes you can approximate that this roller is 24" long, so they are using a wide robot style. Also the diameter is about 3"~4" based on the fact that pneumatic tubes are .25 in OD. Also the fact that the tubes aren't squared off but have pointed cuts lead me to believe that they had to be either threaded through something or squeezed into something tight. Maybe a foam covered roller? Like a paint roller?
"Everything we produce is made of: Duct Tape, zip ties, and hope" - Christian Allinson 1458
Anyone can watch Westcoast Choppers and see adults build things, but FIRST is great because it encourages kids to do the building and adults to do the watching.
GO DANVILLANS!!
Unread 29-01-2009, 11:30
ducttapedude ducttapedude is offline
AKA: Peter
FRC #0233 (The Pink Team)
ducttapedude has a spectacular aura aboutducttapedude has a spectacular aura aboutducttapedude has a spectacular aura about
Send a message via AIM to ducttapedude
It could be a roller, or is it a main drum in the center of their robot??
Think Poof
Unread 29-01-2009, 12:27
Woody1458's Avatar
AKA: Woody Jansen
Possible, but two facts lead me away form this.
Diameter- From what I have seen team that do a Helix Hopper use a larger main drum than this (http://www.youtube.com/watch?v=LlUgVpRckS8v)
Tube placement - They placed their tubes with large gaps in between (~1.5") which would give them plenty of space to run loop tubing inside of, using the finger tubes as containment.
GO DANVILLANS!!
Unread 29-01-2009, 12:35
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
PVC roller. Surgical Tubing "fingers"
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 29-01-2009, 13:08
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
It looks better ths way:
LINK
Former Mentor Team 1771
Former mentor Team 4509
Unread 29-01-2009, 19:54
Manoel's Avatar
Listen to those pink guys, they sure can smell a drum roller five thousand miles away
The "normal" (pre-filter) picture shows a ball bearing at the end of the ~4" OD (10 cm, actually) PVC tube. The perspective threw you off big time, the roller was 54 inches long when we took the picture, it's been trimmed a foot or so after that.
We chamfered the pneumatic tubes to make it easier to insert them - there's a 0.8 mm interference fit between tube and hole, and we got a lot of calloused students and mentors
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 29-01-2009, 21:11
5n1p3r's Avatar
5n1p3r 5n1p3r is offline
IM 5n1p3r
AKA: Matthew
FRC #0714 (Team Panthera)
5n1p3r will become famous soon enough5n1p3r will become famous soon enough
Send a message via AIM to 5n1p3r
Thumbs up Re: pic: Team 383 teaser
Everyone else pretty much just got wat it was so im not gonna repeat it, either way IT LOOKS COOL! lol
pic: Team 383 teaser Manoel Extra Discussion 11 10-02-2008 09:07
Team 383 teaser video Manoel Robot Showcase 5 31-01-2008 22:46
pic: Team 383 mecanums Manoel Robot Showcase 10 31-01-2008 19:37
pic: Team 383 2007 bot corel draw Aldabe Extra Discussion 4 10-03-2007 10:18
pic: team #2247 come to visit team #383 mayah Extra Discussion 1 29-01-2007 12:30
