Go to Post Polycord. It was used in all sorts of ball systems in 2009, and on some of the 2007 claws. It's not too hard to fuse together by hand with some heat and patience. - AustinSchuh [more]
Unread 29-01-2009, 11:11
Tack610's Avatar
Tack610 Tack610 is offline
FRC #2413
Tack610 is an unknown quantity at this point
Control System Stopped Working after switching into Auto mod - Was: Help were stumped
Ok team 2413 here, to start off we have a running robot, well had a running robot. One day while test driving the robot someone accidentally hit the autonomous swith on the Driver station and thats when everything went wrong.
When we turn everything on we can get signal to and from the robot. The buttons on the joystick still light up the LED's on the cRIO but when moving the joysticks, the robot doesnt move. We' double and triple checked all the wiring and everything seems to be where it needs to go. The jaguars dont seem to get a signal though they stay flashing an orange/yellow color.
We have replaced all things replaceable, jaaguar, sidecar, wiring, battery, and nothing is working. We've been stumped for three days and need some major help.
P. S. we have everyting enabled and on teleoperated on the DS.
Joe
Unread 29-01-2009, 11:15
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Help were stumped
I wonder if the driver station got "zapped"?
http://usfirst.org/uploadedFiles/Dri...structions.pdf
Unread 29-01-2009, 11:19
Electricia 1599's Avatar
Electricia 1599 Electricia 1599 is offline
2nd Solutions E-Cycle Program Head
AKA: Devyn McIver
FRC #1599 (Atlee Robotics)
Electricia 1599 is an unknown quantity at this point
Send a message via AIM to Electricia 1599 Send a message via Yahoo to Electricia 1599
Smile Re: Help were stumped
ok, I understand the problem, our robot did the same thing. We think its the controlers. They have been sending out signals from time to time but are not working correctly. We know this because we wused old electronics form last year and the programing works fine and the robot runs perfectly. Try using different joysticks. Hope this helps.
Alex
Unread 29-01-2009, 11:25
Tack610's Avatar
FRC #2413
Thats what we were thinking too but we dont want to go out and spend the money on new joysticks to not have that be the problem
Joe
Unread 29-01-2009, 11:52
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Connect the joysticks to a computer and test them in the control panels under joysticks and controllers.
Unread 29-01-2009, 11:56
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Control System Stopped Working after switching into Auto mod - Was: Help were stu
Question:
When you have everything turned on, booted up, etc. etc and you think it should be working, what does the screen on the Driver Station say next to "Battery:"?
Unread 29-01-2009, 13:49
Tack610's Avatar
FRC #2413
the battery says 00.00V which is what it said when it still worked. For a time being it had said 00.19V i dont know what that means though.
Joe
Unread 29-01-2009, 14:14
Originally Posted by Tack610 View Post
The buttons on the joystick still light up the LED's on the cRIO...
Can you elaborate on that?
That means you don't have battery voltage going to the battery monitor circuitry on the analog breakout plugged in to the analog input module installed in slot 1 of the cRIO. Make sure the I7 selection jumper is installed between the outer two pins on that breakout, and make sure you have power to the WAGO connector on that breakout.
Unread 29-01-2009, 18:09
Wayte Wayte is offline
FRC #2413
Wayte is an unknown quantity at this point
OK, umm the cRIO has the LED's on one of the slots, and when you press the buttons on the joystick the the lights go on and off. But the joysticks arent responding to the jaguars and weve even replaced the jaguars
Remember there are 3 ways to solve any problem:
1. The easy way
2. The hard way
3. With fire
Unread 29-01-2009, 19:48
Tack610's Avatar
FRC #2413
Ok se weve tested the joysticks and they are working correctly. What does the "being zapped" have to do with the DS? like what does that typically do the the DS?
Joe
Control System Problem Help? rogeringalsbe FRC Control System 7 13-01-2009 20:41
So Cal Teams Control System Help ChrisH FRC Control System 5 06-01-2009 21:57
GUI stopped working jgannon Programming 5 08-04-2007 01:09
Camera Working...then mysteriously stopped comwiz7 Programming 14 27-01-2007 12:11
Control System, Joystick mod? Jordan A. Technical Discussion 16 13-02-2002 02:29
