Go to Post Silly FIRST mentor -- actually spending brain power caring about a sporting event occuring during build season! - Aidan F. Browne [more]
Unread 29-01-2009, 01:58
pic: Anyone doing this? **Not a MORT Teaser**
Unread 29-01-2009, 02:01
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Re: pic: Anyone doing this?
First con that comes to mind is weight. Conveyor belts give the same, possibly better, functionality with less rollers, bearing, chain, etc.
I'm sure for some teams this design may be more feasible to fabricate, lathing out groves in pipe for round belting is a bit of a challenge...
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 29-01-2009, 09:20
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Too many moving parts.
Unread 29-01-2009, 09:22
1708xMr.Roboto's Avatar
1708xMr.Roboto 1708xMr.Roboto is offline
Eddie
AKA: Eddie
FRC #1708 (AMPED Robotics)
Team Role: Driver
1708xMr.Roboto will become famous soon enough
Send a message via AIM to 1708xMr.Roboto Send a message via MSN to 1708xMr.Roboto
Yeah we were thinking about the same design. Were not positive what were doing yet, the drawing looks great.
Facebook 1 - Chief Delphi 19382193
Unread 29-01-2009, 09:28
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
We originally tried a variant of this with a twist - the rollers would be spin at increasing rates to accelerate the balls. It was a cute idea, but never produced a fully working prototype since we decided that a) it would be heavy, and b) more moving parts = more likely to fail.
Good luck!
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 29-01-2009, 09:54
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
We used a similar approach on our robot with 6 rollers (3/4" PVC tube with 2.5" pool noodles).
We use the pvc as a shaft and attach plastic #25 sprockets between each endcap on the pvc. We have tested this collector mechanism for 1 week without any significant failures in the rollers.
For most teams without polycord, this is a simple workable solution.
Check out our video or gallery. We should be putting up a video of our robot collecting 20 balls and then dumping them in 20 seconds !
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 29-01-2009, 12:11
run the trap!!!
Team Role: Human Player
No we didn't decide to do this, it wasn't even really considered b/c it wouldn't have worked with our design.
But I would like to know what kind of rubber those "rubber tubes" are, both Akash's and the Disco-bot's.
We are going to have an intake roller, and slipping a rubber tube over it for traction sounds like a really elegant solution (as opposed to wraping neoprene whether stripping around it )
-Philip J. Fry
Unread 29-01-2009, 12:21
MrForbes's Avatar
AKA: Jim
Have you looked into Plasti Dip spray rubber coating?
they have it at a local Sutherlands store
Unread 29-01-2009, 14:58
Again this isn't a design we're using.
The rubber that we used last year on our bot's rollers was actually the lining of a rubber innertube. We had just enough at a mentor's house to use and it worked perfectly.
Unread 29-01-2009, 16:22
Cjmovie's Avatar
Cjmovie Cjmovie is offline
1293 Resident Hacker
AKA: Christopher Corsi
FRC #1293 (D5 Robotics)
Cjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to all
Our team is using a variant of this, which allows for using less rollers to ascend to the top, and also allows the roller system to double as ball storage (without any "hopper", we can hold around 20-25 orbit balls). In fact, we've managed to get the rollers to do everything manipulative on the bot, without any major modifications to the roller system at any point (that is, it's almost symmetrical over a horizontal line through the middle).
We'll post some pictures once we have a 'bot up and running, which hopefully won't be too much longer.
D5 Robotics, Team 1293: Programmer, CAD'er, Mechanical, Electrical... I've made my rounds.
Events: 2006-2009 Palmetto Regional
Website: http://d5robotics.org/
Unread 30-01-2009, 00:18
lynca's Avatar
Andrew Lynch
The black mat we use is drawer liner from Wal-mart. We use zip ties to squeeze the black mat around a pool noodle.
If we encounter a ball jam the noodle will eventually slip on the 3/4" pvc rod preventing the #25 chain from skipping or stalling the motor.
Check out our gallery for more details, http://2009.discobots.org/node/34
Unread 30-01-2009, 00:25
MrForbes's Avatar
AKA: Jim
We're using black mat from Walmart too, on our helix drive. We have flaps of it sticking out, brushing the balls up the helix. Kind of hard to see in the video because it's on black ABS pipe.
http://www.chiefdelphi.com/forums/sh...ad.php?t=73219
pic: Does anyone know who this belongs to?! Dylan Gramlich Extra Discussion 3 20-01-2007 19:14
What are you doing this year? 358_4_Life Rules/Strategy 4 16-01-2007 17:23
pic: Can anyone identify this man? ;-) CD47-Bot Extra Discussion 22 07-07-2006 09:46
pic: Can anyone else do this ? CD47-Bot Extra Discussion 8 16-03-2003 12:20
Why is FIRST doing this??? Harrison Technical Discussion 8 25-01-2003 19:44
