Go to Post To put it simply: An adult coach impacts a team for two minutes. An adult mentor impacts a team for a lifetime. - dlavery [more]
  #31   Spotlight this post!
Unread 27-01-2009, 20:42
DonRotolo's Avatar
Back to humble
FRC #0832
Re: pic: DOC V: THE RING OF FIRE
So let me get this straight: Each of those tubes will spew ignited propane at the opponent, melting them to regolith so you can score on them?
What? That's not what "Ring of Fire" means?
Oh.
Actually, I like the design, and the CAD skills are excellent. I wonder if the wheelbase is too short, in that it might affect stability in a collision by causing the robot to tip over forwards or backwards. That can be managed in other ways, but it gets tricky. Also, using the bumpers as part of the frame's structure is a good idea, especially if you use high-grade material (not regular sheathing grade). Our chassis has a roughly similar shape, and we had some problems with flexing (try lifting a front corent); be prepared to address this as well.
Very nice!
  #32   Spotlight this post!
Unread 27-01-2009, 23:41
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Are you making sure the cRIO case is electrically insulated from the chassis? It looks like you might be mounting it on metal.
That said, this is some beautiful CAD work and an interesting design. I hope it works well for you.
  #33   Spotlight this post!
Unread 28-01-2009, 10:25
swamp_child's Avatar
swamp_child swamp_child is offline
AKA: Cody
FRC #0179 (Children Of The Swamp)
swamp_child is a name known to allswamp_child is a name known to allswamp_child is a name known to allswamp_child is a name known to allswamp_child is a name known to allswamp_child is a name known to all
Are you planning on doing traction control with that wheel in the back?
2009 Florida Champions thanks to 233 and 1649!
2008 UCF finalists thanks to 69 and 342
2007 world Finalist, thanks to 233 and 71, we love you guys
2007 Archemedies undefeated champions, thanks to 233 and 71
2007 UCF finalists thanks to 1902 108 and 386
  #34   Spotlight this post!
Unread 28-01-2009, 18:52
bhsrobotics1671's Avatar
bhsrobotics1671 bhsrobotics1671 is offline
Andrew Nabors
AKA: Andrew Nabors
FRC #1671 (Buchanan Bird Brains)
bhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to behold
Originally Posted by newyorkjr View Post
So the balls are pulled out by gravity? Conveyer to get it up there?
In this design, having any kind of launcher at the end of the bot is redundant since the pipes direct it at such a low angle.
Only problem is distance. Even at a height of 5 feet, you may be able to get a ball at max 3 - 5 feet. There is also the penalty of getting hooked onto your opponets trailer. I dont know if that was part of your stratgey but you defintately need to cut the pipes back in order to ensure that you will not get a penalty by accidentally hooking onto a trailer.
*I made spelling mistakes, I know*
We have a mechanism at the top helping the balls out.
Buchanan Bird Brains - FRC Team 1671
2015 FIRST World Champions
118, 1678, 1671, 5012
  #35   Spotlight this post!
Unread 28-01-2009, 18:54
Andrew Nabors
AKA: Andrew Nabors
The back wheel is raised up off the floor about 0.2" keeping our robot from tipping backwards.
  #36   Spotlight this post!
Unread 28-01-2009, 19:07
Dr Theta's Avatar
Dr Theta Dr Theta is offline
Lead Mentor
AKA: Derek Messer
FRC #2232 (Deus Ex Machina)
Dr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud of
Is that a compressor I see in the back right corner?
  #37   Spotlight this post!
Unread 28-01-2009, 19:13
Andrew Nabors
AKA: Andrew Nabors
yes it is... but we have since gone away with pneumatics.
  #38   Spotlight this post!
Unread 29-01-2009, 13:07
newyorkjr newyorkjr is offline
FRC #1477
newyorkjr is an unknown quantity at this point
Yeah, I can see that. I'm also assuming that the device to help pull the balls out also pulls the balls up to the top of the robot. But that still means that you don't have that much range. So I'm guessing that your plan is to "corner" an opponet's trailer and dump as many balls as possible into the trailer. That means that whatever encourages the balls to leave ur bot must have the ability to get a lot of them out in a very short period of time. Which also means that whatever system that you are using to get the balls up to the top of the bot must be able to get them up at a very quick pace (cim with 4:1?).
But thats just guesses.
  #39   Spotlight this post!
Unread 29-01-2009, 13:32
Andrew Nabors
AKA: Andrew Nabors
There are 3 mechanisms:
1 sucking the balls in
1 pulling the balls up
1 pushing the balls out
pic: FIRST RING matt 1923 Extra Discussion 33 04-03-2008 21:35
pic: Championship Ring KF987 Extra Discussion 8 10-07-2007 17:41
pic: Logo on Ring Donut Chit-Chat 14 30-12-2006 20:33
The Ring Collin Fultz Chit-Chat 26 07-02-2003 16:18
Presenting the FIRST forum ring archiver 2001 0 24-06-2002 00:42
