Go to Post I wouldn't trade my FIRST experiences for the world. - Koko Ed [more]
Unread 27-01-2009, 18:17
VeedotJaydot VeedotJaydot is offline
FRC #1379
VeedotJaydot is an unknown quantity at this point
Accelerometer Problems
We just got our accelerometer wired up and connected, however, it is not outputting any acceleration. We think our code should be functional, but if someone could post some working code so that we could test if the wiring is defective or not, then I would be very appreciative.
Unread 27-01-2009, 21:01
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Accelerometer Problems
There are several posts on correct wiring; search them out and look if the wiring is right first.
Or post how you wired it so we can check it.
Unread 28-01-2009, 15:04
FRC #1379
Here are some pictures of how it is wired, forgive me if they are bad angles/bad quality. Also, here is a rough diagram of how it is wired:
o=wired
x=unwired
X Y Z
o o o (sig)
o o x (5v)
o o o (0v/ground)
Also, to expound on our problem, the only outputs we get are either constant negative numbers (ex: an unchanging -.983) or a sequence of bizzare negative numbers.
Unread 29-01-2009, 00:09
That only shows us one end of the connection. What we really needed to know is where the other end of each of those wires is going.
Unread 29-01-2009, 14:54
FRC #1379
Here are some picture of the accelerometer connected to the analog module, as requested. Sorry in advance again if these are low quality/insufficient.
Unread 29-01-2009, 16:19
FRC #1379
Sorry to double post, but we resolved the problem. It seemed that we needed to scale the accelerometer drasticly to have any useful value.
Unread 29-01-2009, 16:26
I hope you merely unplugged the 12 volt supply from that analog breakout's power connector so you could get a good photo of the sensor cables...
...but in case that's an accurate picture of how your control system looks when you're running it, the missing power connection explains your problem perfectly. The 12 volt input to the breakout is used to generate the 5 volts to power the accelerometer.
Just so we're clear on this, the tiny green LED on the analog breakout board needs to light up when you power up the control system. If it doesn't, you're not providing power to the sensors.
Unread 29-01-2009, 16:59
I use this VI to test accelerometer wiring. It isn't ready for prime time, so please excuse any messiness. If someone wants to pretty it up and repost it, I'd be eternally grateful for at least a week.
It does silly things like assume everything is plugged into the first bumper, and I haven't figured out how to get the time to display on the waveform chart properly yet. I'm still learning this labview thing.
TODO:
Add miswiring indicators (alert! Y axis is unplugged!)
Add out of spec indicators (alert! you are on the moon!)
Prettify it.
gyro and accelerometer problems paulcd2000 Programming 6 16-02-2008 15:17
Accelerometer railerobotics Programming 1 27-01-2006 02:59
accelerometer problems kjohnson Programming 3 02-02-2005 10:53
Accelerometer Tom McCurdy Programming 5 30-01-2005 23:45
Accelerometer buss Electrical 1 09-01-2005 00:10
