Go to Post An awesome unveiling video is not necessarily an indicator of onfield performance. - ToddF [more]
Unread 29-01-2009, 18:04
HotWings HotWings is offline
AKA: Jon
FRC #0548 (Robostangs)
Team Role: Webmaster
HotWings is on a distinguished road
Legality - Splitting PWM cables for servo motors
Our team is running low on PWM ports, and Me and a teamate have gone through the rules several times, and it leaves this quesiton we have very gray. We want to know if it is legal to hook more than 1 servo motor to 1 pwm port. (Meaning have a Y-type cable to split the PWM to run 2 servo's, etc).
We are in a crunch, like you are too, a quick response would be greatly appreciated.
Unread 29-01-2009, 18:07
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Legality - Splitting PWM cables for servo motors
I don't have time to look through the rules right now and decide if this is legal or not, but I do have another suggestion for you.
Teams are provided with 2 Digital I/O modules for the cRIO and 2 Digital Sidecars. Are you currently using both? This would provide a total of 20 PWM ports if memory serves which would be an awful lot to be using on one robot.
Unread 29-01-2009, 18:14
AKA: Jon
yes we are using both. we have A LOT of servos and pwm suckers.
Unread 29-01-2009, 19:59
AdamHeard's Avatar
Lead Mentor
I would say it's legal if it's not expressly forbidden in this years rules. This has been legal in the past.
Unread 29-01-2009, 21:42
longrange longrange is offline
FRC #1070 (Royal Robotrons)
longrange is an unknown quantity at this point
You can't split the output of a victor or jaguar but you can split PWM signals to drive more than one device. We have multiple conveyor belts but they use the same type of motor and always work the same direction so we are splitting the PWM signal going to the victors.
Unread 29-01-2009, 22:39
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
There are electrical limitations on how many servos can be run off a PWM, but I don't know of a specific rule prohibiting this. We have used servos to shift our transmissions in the past using a "Y" PWM cable, since they have to shift at the same time. You can always use the Q & A to get an official answer, and I will look over the diagrams and rules for anything specific.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 29-01-2009, 22:43
I would be very interested to know what all you are using.
Unread 29-01-2009, 23:13
Hodge1
FIRST lists in the manual that each sidecar PWM output has a max of 15 mA of current. You can go to this link to see for yourself on Page 30.
http://www.usfirst.org/uploadedFiles...s-Rev-0-5a.pdf
I could not find an amp rating on the HiTec servos, only voltage and speed on the HiTech site. You can call HiTec at 858-748-6948 and speak to their tech dept on feasability and specs. The drawings of the sidecar outputs show one servo per PWM. Remember running amperage will be much lower than stall amperage, which is what will cause you problems (aka blown) in the circuit.
Sweat the details
Unread 29-01-2009, 23:32
Cjmovie's Avatar
Cjmovie Cjmovie is offline
1293 Resident Hacker
AKA: Christopher Corsi
FRC #1293 (D5 Robotics)
Cjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to all
When you place a jumper over the supply-enable pins for the PWMs (which must be done for those running servos), the 6V power supply is tied into the cable going to the servo. This has a much higher allowance, and the data sheet for it is found on page 31 (IIRC).
D5 Robotics, Team 1293: Programmer, CAD'er, Mechanical, Electrical... I've made my rounds.
Events: 2006-2009 Palmetto Regional
Website: http://d5robotics.org/
Unread 30-01-2009, 08:47
The 15mA refers to the drive strength of the signal. Jaguars and Victors have opto-isolators on their signal input, which means they draw current. I believe that most servos don't have an opto (though I could be wrong).
The servo 6V supply has 3A available for actual power.
I do not actually know the rules on N servos per output. Please Q&A it.
Unread 30-01-2009, 09:55
Racer26 Racer26 is offline
I gotta admit I'm curious as to what you could possibly be doing that would require 20 PWMs... we've never had more than 16 available to us up to this year, and even then I don't think my team's ever used more than 10 and that was a complex robot.
Unread 30-01-2009, 14:22
Tt321b Tt321b is offline
AKA: Tony
FRC #1803
Tt321b is a jewel in the roughTt321b is a jewel in the roughTt321b is a jewel in the rough
Send a message via AIM to Tt321b
Last year our team has split the pwm signal to two shifting servos and the inspectors were ok with it. In '06 we split the signal to two victors and I don't think that the inspectors were not so happy with it.
You might want to consider using some relays to run motors instead of just speed controls to free up some pwm ports.
Team 1803
2006 SBPLI Regional
- Highest Seeded Rookie
- Rookie All-Star Award
2008 SBPLI Regional
- Regional Finalists (358, 533, 1803)
Unread 30-01-2009, 14:31
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
I'm wondering the same thing. If I counted right, there are 15 motors available for use. Even if you power all 15 through speed controllers you would still need to be adding 6 or more servos to run out of PWM ports. That is one heck of a complex bot to have that many moving parts.
Unread 30-01-2009, 23:35
DtD's Avatar
DtD DtD is offline
I hope the watchdog starves!
AKA: Pathogen David
FRC #2410 (The Metal Mustangs (Merged from 2334, Hazmat Robotics))
DtD will become famous soon enoughDtD will become famous soon enough
Can you post a picture of your bot, I am very curious to see why you are needing all thoose PWM ports!
~DtD
Unread 01-02-2009, 16:03
Hotwings,
In the past the RC controller manual allowed a "y" cord to establish a PWM signal to be split to two speed controllers. Since Eric has pointed out the DSC is current limiited to 15 ma, I would not suggest you split a PWM signal on this year's control system. You run the risk of over current on a single PWM output with two opto couplers so connected. Also as Eric pointed out, the jumper to allow power to a servos is limited to 3 amps. You will need to determine the current rating on each servo type you will be using and make sure your design would remain below the three amps.
PWM Cables Mechanical Electrical 6 05-05-2008 21:35
custom PWM cables bruss6 Electrical 6 16-02-2007 08:33
Best place for PWM cables MaddyW Electrical 13 14-10-2006 23:37
PWM Cables Alex Cormier FIRST Tech Challenge 15 13-08-2006 09:48
PWM Cables zachriggle Electrical 3 04-02-2006 13:54
