Go to Post The competition is about MUCH more than just the robot. If kids are glued to the robot all of the time, then they miss the rest of it... the other fun stuff, what makes FIRST, FIRST. - Kims Robot [more]
Unread 25-01-2009, 16:18
Bus1012 Bus1012 is offline
FRC #0314
Bus1012 is an unknown quantity at this point
JPEG Images for Inventor
Does anybody know how to save a Inventor Drawing as a JPEG Image file????
Any help is gladly appreciated....
-Airman Bus
Unread 25-01-2009, 16:45
Lesman's Avatar
Lesman Lesman is offline
FRC #1014 (Bad Robot)
Lesman will become famous soon enough
Re: JPEG Images for Inventor
I use pdfcreator and just print the drawing to a PDF file. It turns out really well (looks better than looking at it from one of Autodesks file viewers) and it's cross platform! And it scales well! AND! you can print it to scale. It's good stuff.
Unread 25-01-2009, 16:46
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Go to: File> Save Copy As> Select the File type as JPEG and it'll save whats on the screen as a JPEG.
-Dustin Benedict
Unread 25-01-2009, 17:08
FRC #0314
Thanks guys really appreciate it
Unread 25-01-2009, 17:10
FRC #0314
Hows everyone's inventor projects coming
Unread 27-01-2009, 15:56
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
Issues with constraining extruded aluminum
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 29-01-2009, 09:38
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
In addition to the Save Copy As type *.jpg method
there is also the Applications>Inventor Studio method that will give you a higher quality Rendering.
Autodesk Inventor Certified Expert
Certified SolidWorks Professional
AU 2007 Avatech Altogether Smarter Inventor Challenge 1st Place
http://home.pct.edu/~jmather/content..._tutorials.htm
Unread 29-01-2009, 19:13
FRC #0314
Thank you all for the help in saving my Inventor project as a .jpg image
Unread 29-01-2009, 21:13
5n1p3r's Avatar
5n1p3r 5n1p3r is offline
IM 5n1p3r
AKA: Matthew
FRC #0714 (Team Panthera)
5n1p3r will become famous soon enough5n1p3r will become famous soon enough
Send a message via AIM to 5n1p3r
Arrow Re: JPEG Images for Inventor
Im actually doing pretty well on my inventor project, my frames awesome, cant wait to throw it out on the simulation track
Unread 29-01-2009, 21:48
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
I'm not familiar with the profile your trying to constrain but it may be easiest to create a reference plane along the face that you are trying to constrain it to. Depending whether or not your trying to create dynamic constraints. When I first started I never had considered using reference plains for constraints but it works well enough on strange shapes.
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 29-01-2009, 22:15
writchie writchie is offline
Engineering Mentor
AKA: Wally Ritchie
FRC #2152 (Team Daytona)
writchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond repute
If you're trying to constrain accurate 8020 profiles there is only a tiny flat section on the surface. If you are using flush constraints this is the only surface that will work as expected.
You often have to zoom in quite a bit for the flat strip to show up. Once you learn how to do this it will become second nature.
Also beware that the extrusions are 7 mil smaller their nominal length. You might have to use an offset to account for this.
80/20 has a 4 degree angle to make a vibration free connection. There is nothing stopping you from modifying the profile to be more square and easier to work with for your model.
Inventor images from Industry pmax Inventor 0 08-01-2007 19:20
Inventor Images help Dylan Gramlich Inventor 6 25-12-2006 23:05
pic: ParagonUTCteam.jpeg Steve Howland Extra Discussion 1 13-03-2006 21:58
Images for 2006 boy_scout72688 General Forum 1 10-01-2006 11:08
Writing and Images on Inventor Designs Jan Olligs Inventor 0 23-02-2002 11:44
