Go to Post That's just the thing about plastic or brass gears; they tend to morph into plastic or brass washers real fast. - Nick Seidl [more]
Unread 08-01-2009, 11:17
finman's Avatar
finman finman is offline
Programmer
AKA: Chris Finley
FRC #0888 (Robotiators)
finman is an unknown quantity at this point
Tank Drive with Advanced Framework in Labview
i have successfully implemented a tank drive system with the basic robot framework in labview, but i have not been able to do so with the advanced framework. i am still having a little bit of trouble understanding where all of the variables are stored in labview, in particular the "joystickdevref". i figured out how to add a second reference for my second joystick in the global variables vi, but it won't change to USB2. after i change it, save it, close it, and reopen it, both references say USB1 again. does anyone know what my problem is? also, can you explain exactly what the joystickdevref variables are?
"Red goes to black, right guys?" ~Mike Mascaro: Our Fearless Leader
Unread 08-01-2009, 11:59
s0crates s0crates is offline
s0crates is on a distinguished road
Re: Tank Drive with Advanced Framework in Labview
You have to open it with jostick=>open - otherwise you just have an empty variable, essentially. The space is reserved but you need to initialize it with joystick=>open and stick its output joystickdevref into there.
-jonathan
Unread 29-01-2009, 19:22
lookitsnichole lookitsnichole is offline
FRC #2545
lookitsnichole is an unknown quantity at this point
Where/how do you open it with joystick->open? We can't seem to find it. Thanks in advance.
Unread 29-01-2009, 23:07
There is a sidebar with all the robotics vis etc as well as labview functions - access it from View->Functions Palette when in block diagram or right click.
joystick-open is under WPI Robotics Library->DriverStation->Joystick.
-jonathan
Unread 30-01-2009, 13:35
Look for where the existing joystick is opened in Teleop.vi.
In Teleop.vi the case structure has:
-- An "Init" section where the joystick open's are done
-- A "Stop" section where the joystick is closed
-- An "Execute" section where the joystick gets used
Tank Drive Sauce Programming 1 05-01-2009 18:50
New TipJar Training Video - Making Friends with the FRC Advanced Robot Framework LVMastery Programming 0 05-01-2009 14:54
Please Help, Don't Know How to Implement Tank Drive in LabView CVassos NI LabVIEW 5 24-12-2008 16:55
Major problems with tank tread drive Lord Nerdlinger Technical Discussion 13 23-02-2004 21:15
tank drive Stormhammer Programming 11 29-01-2004 23:08
