Go to Post One wondered why they couldn't practice in the gym that day - because the robotics team had it reserved was the answer. "Oh, we have a robotics team?" Sigh. This is a team with a low number. They've been around for at least a dozen years. There's still a lot more culture-changing to do. - GaryVoshol [more]
Unread 29-01-2009, 20:03
DanL DanL is offline
Crusty Mentor
FRC #0097
DanL is just really niceDanL is just really niceDanL is just really niceDanL is just really niceDanL is just really nice
Send a message via AIM to DanL
Re: Traction Control for a Turning Tank-Drive
How's this for some brief thinking? (Disclaimer: probably requires a physics class under your belt, preferably one with some calc)
1. Measure wheel rotational velocities (eg wheel encoders).
2. Assume no-slip condition, and calculate force vectors exerted by each wheel. Estimate robot-trailer CoM, and use vector arithmetic to calculate assumed torque around the CoM.
3. Using a gyro (needs to be right on the CoM?), calculate actual angular acceleration.
4. Compare actual angular acceleration to predicted angular acceleration (derived from torque in step 2) -- this is your traction control system's wheel-slip-error measurement. If actual A_angular < predicted A_angular, you're slipping and you need to cut power.
Does this sound legit to you more mechanically-inclined people out there? It's an approximation since we're ignoring all the friction forces created by the the robot/trailer wheels sliding, but will it be close enough?
How about the process of combining linear traction control with angular traction control? Do people predict any weird dependencies, or can we just use good ol' superposition?
Dan L
Team 97 Mentor
Software Engineer, Vecna Technologies
Implementing Traction Control for an advantage in the 2009 game DonRotolo Programming 143 27-02-2009 11:53
Using encoders for traction control help ellisk Programming 13 03-02-2009 19:56
Swerve/crab drive and tank turning activemx Technical Discussion 9 23-02-2004 18:26
traction vs turning HEPL andy Technical Discussion 2 10-02-2003 22:51
tank traction vs. speed DaBruteForceGuy General Forum 11 23-02-2002 15:23
