Go to Post You know you've overdosed on FIRST when you hear people yell "CHARGE" and you get confused and lost when you look and see baseball and not robots - thatphotochick [more]
Unread 29-01-2009, 21:02
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Flexibility of steel alloys
I'm trying to make a purchasing decision on steel rods from McMaster, and I don't have nearly enough background in materials science to make the best choice. We already bought a piece of 1006, and found it to be too flexible. The other options in the size we need are 1018, A2, D2, M2/M7, O1, S7, and W1. McMaster lists hardness and yield strength for these materials, but my understanding is that these are not directly related to the property I'm interested in. Is there a chart or something somewhere that will tell me which alloy will flex the least under a fairly constant load? My gut says that the one labeled "very hard" (the M2/M7) is what I'm looking for, but I'd like numbers or an expert opinion to back it up.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 29-01-2009, 22:40
SNelson's Avatar
SNelson SNelson is offline
FRC #2034 (The IncrediBulls)
SNelson is an unknown quantity at this point
Re: Flexibility of steel alloys
The properties that defines a materials stiffness are the modulus elasticity or the modulus of rigidity. Which property (mod. of elasticity or mod. of rigidity) matters depends on your particular loading scheme.
Also, a material's hardness generally refers to a material's ability to resist indentations, scratching, etc.
A good resource for material properties is matweb.com. However, most steels have the same modulus of elasticity (~200 GPa). You may consider using a different material, possibly a carbon composite.
If you give me a few more details about how the steel part is being loaded, I might be able to make suggest an alternative material.
Unread 29-01-2009, 23:06
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Another good resource is efunda.com. Tooooons of materials and other information. But a limited number of page views per day unless you pay membership.
Agreed with SNelson, though. Alloying materials primarily affect hardness, yield strength and tensile strength. To increase stiffness, you'll need to move to a different material, or change the cross section of your part. Tubes with larger diameters are much stiffer per pound than rods. So if you can get away with a larger diameter tubular shaft/strut/whatever, it will be much stiffer. Though at that point, it's prone to buckling. So you have your choice of lighter, larger, stiffer, etc.
Unread 29-01-2009, 23:16
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Kevin's suggested website is good...and this probably makes it even more useful.
Unread 30-01-2009, 12:22
Dick Linn's Avatar
no team (Synergy)
The modulus of elasticity for steel varies only slightly between various alloys. Stainless is typically on the low side (28,000 ksi) and something like M4 on the high side (31,000 ksi). There is still not a lot of difference.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 30-01-2009, 13:34
To expand slightly on what Kevin wrote, stiffness varies as the fourth power of cross-section. Making it bigger will pay off faster than making it from different steel alloys.
Now, if you replaced that steel bar with a carbon fiber rod, it would be much stiffer. Not as resistant to side loads, and likely to fail in much more spectacular ways when its load limit is exceeded, but it would be stiffer.
Flexibility of Goal ak_Knight Rules/Strategy 10 09-02-2004 23:17
Welding stainless steel to mild steel... can it be done? Travis Covington Technical Discussion 3 27-01-2004 19:11
Aluminum Alloys ZACH P. Technical Discussion 8 06-11-2003 19:22
Steel Blends Wetzel Technical Discussion 2 15-09-2003 17:01
Steel Edge AJ Howard Rules/Strategy 1 18-01-2002 18:52
