Re: 2 Joysticks, 2 Triggers, 1 relay, 1 problem
Make sure you are using the right constants.
From the Set Relay help: RelayValue specifies whether the relay is configured to move the motor in a forward or reverse direction. Off (0) (Default) Specifies that the motors are off. On (1) Specifies that the motors are on. Forward (2) Specifies that the relay moves the motors in a forward direction. Reverse (3) Specifies that the relay moves the motors in a reverse direction. |
| spike relay problem? | Maxpower57 | Electrical | 15 | 09-04-2012 19:18 |
| [OCCRA]: Problem with the compressor, pressure switch, or Bosch relay. | BrittanyV | OCCRA | 3 | 16-10-2006 15:42 |
| Joystick Triggers No Longer Work | amateurrobotguy | Technical Discussion | 7 | 04-04-2006 13:58 |
| Help! Programming question with triggers | AsimC | Programming | 26 | 18-03-2004 11:00 |
| AVB joysticks..and other analogue joysticks | tml240 | Kit & Additional Hardware | 6 | 07-02-2004 12:45 |
