Go to Post God bless the camera. That's all I gotta say. - Bharat Nain [more]
Unread 29-01-2009, 23:12
starsROBOTICS starsROBOTICS is offline
FRC #2276 (S.T.A.R.S)
starsROBOTICS is on a distinguished road
Re: 2 Joysticks, 2 Triggers, 1 relay, 1 problem
Originally Posted by a3aperez View Post
Make sure you are using the right constants.
From the Set Relay help:
RelayValue specifies whether the relay is configured to move the motor in a forward or reverse direction.
Off (0) (Default) Specifies that the motors are off.
On (1) Specifies that the motors are on.
Forward (2) Specifies that the relay moves the motors in a forward direction.
Reverse (3) Specifies that the relay moves the motors in a reverse direction.
Ok instead of specifying 1,0,2, or 3 i right clicked the left side of the relay terminal and created a constant. I put the constant to the left of the select and wired it to the true statement. Would that be okay or does it have to be a numeric value as in 1,2,3, or 0?
spike relay problem? Maxpower57 Electrical 15 09-04-2012 19:18
[OCCRA]: Problem with the compressor, pressure switch, or Bosch relay. BrittanyV OCCRA 3 16-10-2006 15:42
Joystick Triggers No Longer Work amateurrobotguy Technical Discussion 7 04-04-2006 13:58
Help! Programming question with triggers AsimC Programming 26 18-03-2004 11:00
AVB joysticks..and other analogue joysticks tml240 Kit & Additional Hardware 6 07-02-2004 12:45
