Go to Post ...next years game will hopefully make my head hurt, this years did. - Michael Leicht [more]
Unread 29-01-2009, 17:56
mbone206 mbone206 is offline
FRC #0223
mbone206 is an unknown quantity at this point
Labview servo motor PWM correlation to set VI
The Servo SetVI is '0 to 1'
PWM VIs, 0 to 255 where 1 is full reverse and 255 is full foward
How does Servo '0 to 1' scale with PWM '0 to 255'
Example: If I read back 127 on servo motor using PWM-GetValue VI, what ould be the '0 - 1' position of Servo
new at this, thank you for your patience and support
Unread 29-01-2009, 21:50
Luke Pike's Avatar
Luke Pike Luke Pike is offline
Programmer
FRC #1501 (THRUST)
Luke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to all
Re: Labview servo motor PWM correlation to set VI
I'm not sure what your asking, but here's some info. Servos can get or set angle or position. Angle should be between 0 and 180.
It seems like your using the PWM vi's to set the value? You can set the angle or the position of a servo using the Set Angle and Set Position vi's.
Twitter Profile
Unread 29-01-2009, 23:48
ebmonon36's Avatar
ebmonon36 ebmonon36 is offline
AKA: Eric Bredehoeft
FRC #1018 (Robodevils)
ebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud of
Send a message via AIM to ebmonon36
0=127 - One end of the rotation
1=255 - The other end of rotation.
Any number in between 0 and 1 would be a position between the stops on the servo. 0.5 would be half way.
Unread 30-01-2009, 13:02
FRC #0223
ebomnon - 36 - got it - thanx
Unread 30-01-2009, 14:58
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
This is incorrect. Please bother to actually to do some research on a question before you answer it.
The correct answer is that a 0 to 1 range on the input of a Servo:SetPosition.vi corresponds to an 11 to 253 range of actual PWM values. So in your parlance:
0.0 = 11 One end of rotation
1.0 = 253 The other end of rotation
You can discover this by simply opening up some of the associated VIs. You may even learn something in the process.
Tracking Servo motor with drive motor in Labview mbone206 Technical Discussion 5 28-01-2009 17:32
[FTC]: FTC Servo-Motor Problem with Labview dnhansen FIRST Tech Challenge 1 26-10-2008 00:43
Hanson Hobbies PWM Servo Cable Kits Chris_Elston Electrical 4 21-01-2008 19:12
servo PWM sampling-what Fosc should I use? 3dude_2231 Technical Discussion 6 23-08-2007 13:17
How do you set a speed limit on the servo Fares Programming 6 01-01-2003 15:04
