Go to Post If you have the time to be caught up on Delphi and the Q&A forum, then you have time to go write a WFA entry. No more excuses. Go! Write! Now! :) - Jessica Boucher [more]
Unread 29-01-2009, 21:01
Lord X's Avatar
Lord X Lord X is offline
AKA: Daniel Bramblett
FTC #1510 (Wildcats)
Lord X is an unknown quantity at this point
Exclamation Lab View = big headache
Hello, I am on team 1510 and we have been programming with labview. Yesterday, an error popped up, it was titled "Deployment Error and Warning Resolution".
The conflict message is "Connection failed. The network address might be invalid or the target is not responding."
The weird thing is that the joy sticks we have connected work with the programs. The mentor is baffled and I haven't found a referance for it yet. Any ideas would be very apreciated before I start shaking the laptop till the problem goes way or it breaks.
Daniel Bramblett
Team 1510
Unread 29-01-2009, 21:32
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
Re: Lab View = big headache
Does hitting the white arrow (without full deployment) work?
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Unread 29-01-2009, 21:35
Lord X's Avatar
The program is the unbroken white arrow if that is what you mean, no it doesn't work with a broken arrow.
Daniel Bramblett
Team 1510
Unread 29-01-2009, 21:44
GRS GRS is offline
FRC #1764
GRS is an unknown quantity at this point
Does the back of the LinkSys router have anything plugged into the WAN port?
It shouldn't.
Unread 29-01-2009, 21:46
Lord X's Avatar
I am afraid not, we are using direct connection.
Unread 29-01-2009, 21:48
Burmeister #279's Avatar
Burmeister #279 Burmeister #279 is offline
What Time Is It?
AKA: Nick Burmeister
FRC #0279 (TechFusion)
Burmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of light
Send a message via AIM to Burmeister #279
i know it may seem blatantly obvious, but have you tried unplugging everything [DS, Battery, router] and then replugging it in?
and as far as the joysticks still working, its because [i'm guessing] there's a program already deployed [downloaded and set to autorun] and its running that program. also, check the IP on the project.
i'm currently on AIM so if you still need help message me [s/n below]
WHAT TIME IS IT? TWO SEVEN NINE!!! [Team B =) ] Awards: 4 Safety, 2 Ind. Design, 2 Xerox, 1 Nat. Champs
2009 Buckeye Semi-Finalists (1014 & 695) || 2008 GLR Safety Award || 2006 GLR Safety Award
2005 Buckeye Regional Champs (67 & 274) & GM Industrial Design Award & Safety Award GLR Quarter Finalist & Xerox Creativity Award & Safety Award National Xerox Creativity Award & Curie Quarter Finalist (1126 & 180)
2004 Buckeye Delphi Driving Tomorrows Technology Award & Quarter Finalist GLR Champs Nationals Curie Division Finalist
2003 GLR GM Industrial Design Award || 2001 National Newton Division Winner & National Champions
2000 MI DaimlerChrysler Team Spirit Award
Unread 29-01-2009, 21:53
Lord X's Avatar
We have tried all of those things and the IP address seems ok.
Unread 29-01-2009, 21:57
Lord X's Avatar
I think we found the problem, that problem has gone away for now, now all we have to do is find are program with the wrong data, because it has are entire program in it, but thanks for the help!
Daniel Bramblett
Team 1510
What Time Is It?
good luck with the rest of it then =)
Unread 29-01-2009, 23:53
Mind saying what the problem was so that people searching with a similar problem will be able to get it working?
Unread 30-01-2009, 16:27
Analog's Avatar
Analog Analog is offline
AKA: Bob Most
FRC #2619 (The Charge)
Analog will become famous soon enoughAnalog will become famous soon enough
did you mean "Lab View == big headache"
Unread 17-02-2009, 11:53
shaggy0928 shaggy0928 is offline
FRC #1339
shaggy0928 is an unknown quantity at this point
So yesterday I installed the most recent labview update, and I think I broke labview.
There is a little ! error thing next to "FRC Robot Boot-up Deplyoment" and it just says "the plug-in is not installed on this computer" when I try to use this function.
What did I do???? Any help would be incredibly awesome
P.S. I already tried re-installing the stuff on the DVDs that came with the kit of parts, as well as the most recent update
Unread 17-02-2009, 21:10
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
Direct connection between what? The computer and the cRio? The DS and the cRio? I'm pretty sure the driver station has no DHCP, which I think is required to connect to the cRio, and Windows doesn't either. The router is there because it knows how to handle DHCP requests and can connect several devices together.
Help with programing Tank Drive in Lab View zackcool123 NI LabVIEW 3 18-01-2009 19:49
Vex and lab view 1086VEX Programming 2 02-06-2008 20:42
Lab View Schotty57 Programming 5 02-04-2008 20:24
Lab view licenseing Question Joohoo LabView and Data Acquisition 4 11-01-2007 15:59
CMU Cam + Lab view Question Dillon Compton Programming 6 06-02-2006 12:02
