Go to Post Success is the gleam in a child's eyes when they catch their first glimpse of your creation and their life is forever changed. - SlamminSammy [more]
Unread 26-01-2009, 15:19
furiousgeorge's Avatar
furiousgeorge furiousgeorge is offline
FRC #3055
furiousgeorge will become famous soon enoughfuriousgeorge will become famous soon enough
cRIO buzzing
our cRIO is making a weird buzzing noise, it wasn't making it until recently, does anyone know what this means?
Unread 26-01-2009, 16:06
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Re: cRIO buzzing
Are you positive that it's the cRIO and not the PD? The boost converters in the PD are known to whine (especially with lower battery voltage).
Russ
Unread 26-01-2009, 20:51
crake crake is offline
National Instruments
AKA: Chris Rake
no team (Athena)
crake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond repute
Re: cRIO buzzing
The cRIO also could buzz during current limiting. Is the controller otherwise functional? Can you also check the voltage across the input (V and C).
Unread 27-01-2009, 02:07
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
Re: cRIO buzzing
we had a similar problem with the CRio "buzzing"
Battery voltage was low the CRio was only getting about 16v... which if i recall is under minimum voltage recommendation.
Either just change the batt see if that fixes it or get a multi-meter and check voltages...
Unread 27-01-2009, 10:47
AKA: Chris Rake
no team (Athena)
Re: cRIO buzzing
If you're seeing 16V on cRIO, please check the output of your battery. It would have to be pretty low for the voltage to drop, but I'd like to know what it was.
Unread 27-01-2009, 11:11
Re: cRIO buzzing
16V is symptomatic of either using one of the bad 2008 batteries or using a remarkably discharged battery.
With the bad 2008 batteries, the unloaded voltage may read good, but the loaded voltage will drop like a rock. Please measure it while it is attempting to power the robot.
Also, please confirm by attaching a known good battery.
Unread 27-01-2009, 23:50
popo308's Avatar
AKA: Brent
Re: cRIO buzzing
We were running the robot around for about 20 min ish and it stopped working. noticed the CRio wasn't on so we got the multimeter and the voltage was at 16v put a new battery in and it was back to 24v...
Unread 28-01-2009, 07:19
Re: cRIO buzzing
The fact that you were able to run the battery down so low that the boost converter started to dropout means that the Power Distribution is doing EXACTLY what was intended - ie successfully power the cRIO and wireless adapter until the battery starts sagging < 6V. I'd consider your observations to indicate an excellent test of the PD ... and it easily passed.
Thanks for the feedback! I'll bet you'll be more careful about keeping your batteries topped off from now on
Russ
Unread 28-01-2009, 23:57
popo308's Avatar
AKA: Brent
Re: cRIO buzzing
Russ
Well it was slightly just running it around for a long period of time also the curiosity of how low the voltage can get before the CRio will actually start losing power...
Unread 29-01-2009, 23:48
FRC #3055
Re: cRIO buzzing
thanx everyone! it was the battery, we didn't realize it but when we thought we were charging the battery there wasn't any power running to the battery, so when we thought we had a full charge, we actually had less than 25%, thanx a ton! we were really worried! haha
Unread 30-01-2009, 00:15
Cow Bell Solo's Avatar
Cow Bell Solo Cow Bell Solo is offline
No Stolte No
AKA: Chris
FRC #2194 (Fondy Fire)
Cow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the rough
Send a message via AIM to Cow Bell Solo Send a message via MSN to Cow Bell Solo Send a message via Yahoo to Cow Bell Solo
Re: cRIO buzzing
I would also just like to mention even though you have solved the problem too for others. that if you are using the Jaguars, they have the fans built in unlike the victors and that the fans only turn on when needed, so there can be on and off somewhat buzzing/humming sound.
Who let the Blue Smoke Out
Team 2194 Mentor - 2012-Present - http://fondyfire.com
Team 2207 Alumni - http://whitebearlakerobotics.com
Iowa FIRST LEGO League Planning Team Member - 2010-Present - http://www.isek.iastate.edu/fll
FIRST LEGO League volunteer - 2008-Present
2008: MN Regional Quarterfinalists, Website Excellence
2009: MN North Star Quarterfinalists, recognized for safety, Website Excellence
fried cRio??? morganh2550 FRC Control System 13 24-01-2009 21:11
cRIO v7 fails Peter H FRC Control System 7 18-01-2009 14:26
cRIO Problems computerboi1503 C/C++ 7 11-01-2009 09:35
cRIO Problem Pneumaticsman NI LabVIEW 8 10-01-2009 11:59
cRIO feedback Maxpower57 C/C++ 2 08-01-2009 19:06
