Go to Post This is what I love about FIRST everyone helps and asks why later. - Kyle [more]
Unread 30-01-2009, 01:35
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Re: How to determine rolling resistance.
Originally Posted by BigWhiteYeti View Post
Rolling resistance is essentially determined by deformation, of wheel and ground. Overcoming this resistance has little to do with calculating the torque needed to accelerate your 200lb motorcycle to 30mph as you described. The torque needed depends entirely on the ratio of your driving gear to the diameter of your wheel. It also depends on how quickly you want to do this. You will have to overcome a certain amount of friction and resistance, but up to 30mph these forces will be rather small. Tell me your desired acceleration and gear ratio, and I can tell you your necessary torque.
I did not describe accelerating my 200lb motorcycle to 30 mph. I do not even own a 200lb motorcycle.
So are you telling me the only resistance to roll an object has is wheel deformation?
-John
1557 rolling chassis gorrilla Robot Showcase 4 19-01-2009 22:38
C++ Program to Determine Cost Per Student for Regional neoshaakti Programming 4 10-01-2009 20:22
Battery on-resistance Frank Neuperger Electrical 4 22-01-2007 09:22
pic: Rolling Base CD47-Bot Robot Showcase 7 06-02-2004 01:29
how would U determine the exact speed of your robot? HolyMasamune General Forum 4 29-01-2003 09:44
