Go to Post Andy, you have daughters, would you buy them a Dave doll? - MissInformation [more]
Unread 30-01-2009, 06:46
Doug Leppard's Avatar
Doug Leppard Doug Leppard is offline
FRC #1902 (Exploding Bacon)
Doug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond repute
Send a message via AIM to Doug Leppard
Re: jaguar brake\coast controlling
Originally Posted by brianafischer View Post
To clarify this:
Using a DMM, our team checked the ground path between the Digital Sidecar ground and the Jaguar Brake/Coast Header ground. There was an open circuit (MOhm reading). We tested the Jaguar with a single connection which resulted in the DOUT OFF (0V/coast) state not working. Thus, we added a pull-down resistor (as stated in the spec sheet for the Jaguar) referenced to the GND pin of the Digital Sidecar.
2 wires on the digital sidecar, 1 wire to the jaguar.
Have you had any problem with getting the Jaguar in a coast mode using the jumpers? Also what spec sheet are you referring to and where do I find it.
Trying to help our programmers.
Doug Leppard
Victor Brake/Coast Default FRC4ME Electrical 7 31-03-2008 13:40
Brake / Coast switching for Victors nreyesciena Control System 2 28-01-2008 13:17
Victor 884 Brake/Coast Issues sciguy125 Control System 23 23-01-2005 14:46
Speed Controller brake/coast setting steven114 Electrical 21 03-03-2004 13:05
Brake/Coast Jumper archiver 2001 3 24-06-2002 01:04
