Go to Post I just want to say that the rack 'n roll was my first year with FIRST! It was the best thing I ever did. I cant wait to learn more when we get to start up again! - ctorloey [more]
Unread 29-01-2009, 15:26
TERTOLA TERTOLA is offline
FRC #2513
TERTOLA will become famous soon enoughTERTOLA will become famous soon enough
Rookie Team Again... Need Help
Hey, its Edison High's TERTOLA team here again for basically a 2nd rookie year.
Last year was our first year and every member went on to graduate except me (still a junior). And i was never ones to fancy with the wire and electrical devices. Was wondering whats the basics of the electrical board that goes on the robot?
Can i get a link or list of parts i need to link together like legos?
Much thanks,
(basic parts, not phnumatics or anything)
- T.E.R.T.O.L.A.
Team Year 2001 - Life
Team Year 2002 - Life
Team Year 2003 - Life
Team Year 2004 - Life
Team Year 2005 - Life
Team Year 2006 - Life
Team Year 2007 - Life
Team Year 2008+ - Still got lives, but with a robot.
Unread 29-01-2009, 15:48
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: Rookie Team Again... Need Help
Walk through the control system manual here: http://www.usfirst.org/community/frc....aspx?id=10934
I know, it's 5 chapters, but if you follow the instructions for the benchtop test, it tells you exactly how to go about wiring all the basic components together.
Also available on that page are two pretty important pictures. The Power Distribution Diagram and the Control Layout Diagram should give you your "lego" approach for wiring everything together.
Unread 29-01-2009, 15:55
FRC #2513
I greatly apperciate the help man, thank you very much!
Yeah I looked at that big block earlier this week and knew it was the similiar to last years positive and negative charges, and I already Identifed the parts for the controllers board. thanks!
Unread 30-01-2009, 09:21
Tertola,
There is a variety of great reading on the First website. Check the links under competition documents especially Section 8 Robot rules. The First Suggestions document will walk you through most of what you need. Keep a drawing of the robot wiring diagram handy as you go through this. As a minimum, you will need to mount up the Power Distribution (PD), the CRIO with an analog module in the first slot, an interface card on the analog module with a jumper added for reading the battery voltage (see the Robot rules), the wireless access point(the black box) and a digital module connected to the Digital Sidecar through the 37 pin cable. Once those are mounted, you will need to connect power to the CRIO from the PD, power to the Sidecar and the analog output module. All of the instructions for connection of these devices are in the Control system manual and duplicated on the robot wiring diagram.
Unread 30-01-2009, 09:46
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
http://www2.usfirst.org/ftpdoc/coordination/
You might also want to consider the Robot Quick Build Session materials. Very nice set of step-by-step instructions for putting everything together.
Russ
Unread 30-01-2009, 13:40
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Hi there!
The exact parts you will need for your electronics board depends a bit on your robot and especially what number and types of motors you are planning on using.
The documentation listed by the previous posters, in addition to the Competition Manual, should give you a good start.
I'm a student at the University of Minnesota, so if you or your teammates read through the material and are still completely lost I may be able to make it over and help you out if your team works at your school. I've sent you a PM with my contact info and some times I would be available.
Rookie Team in Grave Need of Help RoboGeek99 General Forum 3 17-02-2008 01:45
Rookie team in need of help Southgate Servo Electrical 5 30-01-2008 16:10
Rookie team in need of help???? RRA4LIFE2 Programming 2 23-01-2008 21:49
Rookie team in need of a lot of help OregonRoboHawks General Forum 25 22-01-2008 10:31
Rookie programmer in need of help. kshot Programming 7 20-01-2005 15:05
