Go to Post Copies gonna copy. - Arpan [more]
Unread 27-01-2009, 03:49
RandomStyuff RandomStyuff is offline
FRC #2212 (Spikes)
RandomStyuff is a jewel in the roughRandomStyuff is a jewel in the roughRandomStyuff is a jewel in the roughRandomStyuff is a jewel in the rough
Servo Porblems
We got a problem in the Servo.
we put up the Jumpers, we checked our program a million times, we also tried to switch the direction of the wires, nothing is working!
It used to work, yet for some reason it recentally stopped working.
Help!
Unread 27-01-2009, 07:48
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Re: Servo Porblems
Check the state of the RSL and try out the Diagnostic Window.
http://thinktank.wpi.edu/article/138
http://decibel.ni.com/content/docs/DOC-3120
Russ
Unread 27-01-2009, 08:56
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Re: Servo Porblems
Does the cRio have to have the Labview image in it to be able to use the diagnostic window or can it have the WindRiver image?
Brian
Brian K
Team 1225 Robotics Mentor
Unread 27-01-2009, 09:44
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Servo Porblems
Help!
*coughs* You switched the direction of the wires? I hate to break it to you, but you might have fried your servo. They don't really like being plugged in backwards. Try to get your hands on a known good servo, and make sure you plug it in correctly.
Unread 27-01-2009, 19:37
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: Servo Porblems
I would also recommend that you try known good servos, but plugging in a servo backwards is not likely to fry it. The PWM (servo) cable has the following signals:
(Black) - (Ground)
(Red) - (Power)
(White) - (Signal)
Reversing the cable would only lead to switching the Ground and Signal wires, meaning that - worse case scenario - the servo detects no control signal and the PWM signal may cause some weird behavior due to "dirty power," but as the voltage across the servo would never exceed the standard operating voltage, I doubt it would damage anything.
Pretty sure the cables were designed this way on purpose.
--Ryan
FRC 766, 2015-, Mentor
Unread 30-01-2009, 10:11
FRC #2212 (Spikes)
Re: Servo Porblems
The Digital Sidecar Status LED is steady on.
Measured 1V between red and black wires and there is also a signal on the signal wire.
Still the servo doesn't work.
Have any idea what's wrong?
Unread 30-01-2009, 10:26
Mark1153 Mark1153 is offline
FRC #1153 (Robo Rebels)
Mark1153 is an unknown quantity at this point
Re: Servo Porblems
We had something like this happen the first week we had the cRIO & digital sidecar.
We forgot to power the digital sidecar. Once we added power it worked fine. Not sure this is your problem - but might be something to check.
servo on DS eitang FRC Control System 1 16-01-2009 14:32
Servo Strength TJ4nier Motors 20 13-02-2007 02:59
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
Servo Plugs CapnBFG Electrical 9 12-07-2005 22:31
Servo MASherry General Forum 6 04-10-2004 22:46
