Go to Post Almost fell out of my chair in the CAD room once. - ChristopherSD [more]
Unread 30-01-2009, 10:55
Re: Common Ground for DSC
Eric,
Although electrically that would seem to work, you would need to follow other electrical system rules for combining wires, insulating same and connecting to the DSC. The wiring convention provided is designed for you to be able to use commonly available PWM cables for interconnect. In general digital inputs will come from different locations on the robot, it would seem that a common point for digital inputs is contrary to good practice. Additionally, using the intended interconnect method will give slightly better noise immunity by providing a separate path for noise on each cable directly to the DSC rather than comprimising all digital inputs with a common ground outside of the DSC. Finally, and more importantly, a common point outside of the DSC gives a single point failure for all digital inputs if the wire breaks or becomes disconnected.
Servos, DSC and labview Team2883 General Forum 2 16-01-2009 14:47
Common Ground? morpheous115 Electrical 8 11-02-2008 11:43
Common ground for sensors? Jared Russell Electrical 1 03-02-2006 07:25
Common Ground on Limit Switches Gary Bonner Electrical 4 18-02-2005 13:24
Common For MAXI MikeDubreuil Electrical 1 10-02-2003 02:35
