Go to Post Those chief delphi kids...they think they're so pimp... - Eugenia Gabrielov [more]
Unread 29-01-2009, 09:40
solomason519 solomason519 is offline
FRC #0519
solomason519 is an unknown quantity at this point
compressor help
hey. i am having trouble firing the festo solenoid. also i am having trouble getting the compressor to stop running. I have the compressor plugged into relay port 1 on the dsc the pressure regulator is plugged into digital io 1 and the solenoid is plugged into the pneumatic bumber port one which is in slot 8 ogf the crio. help please
Unread 29-01-2009, 10:32
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Re: compressor help
I assume that you're actually using a Spike to drive the compressor since it's running?
Do you have any leaks in your system such that the pressure can't get to 120PSI (which is the pressure at which the Nason pressure switch changes state)? Is the compressor running even when the robot is "disabled" (as identified via the screen on the DS)?
Russ
Unread 29-01-2009, 12:48
FRC #0519
Re: compressor help
no the compressor does not run in the disabled state. The pressure does not go above 80 psi and the compressor just continues to run....Help...
Unread 29-01-2009, 12:51
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Re: compressor help
It looks like you have a leak. The compressor will only shut off when the pressure switch changes state. That only happens when the pressure gets to 120 PSI.
You can mix some soap and water and put a little on each fitting, If you get bubbles, there is a leak.
Former Mentor Team 1771
Former mentor Team 4509
Unread 29-01-2009, 13:28
Re: compressor help
Solo,
What pressure is indicated on the pressure guage attached to the regulator? As a test, you can clamp the hose feeding the regulator and see if the system pressure will rise to 120 PSI and turn off the compressor. If system pressure rises to 120 PSI (it should happen pretty quick) then you will know that the leak is downstream of your clamp. If it still does not reach 120 PSI then you know the leak is somewhere between the compressor and the clamp.
Unread 29-01-2009, 13:35
Re: compressor help
It's possible your regulator is plumbed backwards too.
That would regulate the pressure so it could never reach 120psi.
80psi sounds suspiciously like a regulated limit for those of you who run into something like this where it stops right at a particular value every time.
The back of the regulator is marked where the line from the compressor must be attached. It can't go just anywhere.
Unread 30-01-2009, 11:02
FRC #0519
Re: compressor help
i was able to get it working i had the pressure regulator the wrong way. Is there a way to get the pressure to stop at a different value, say like 140 psi. NOw it stops at 120 phi but when i fire the piston once it goes to like seventy. HELP
Unread 30-01-2009, 11:12
Re: compressor help
We're limited to 120psi by the rules (so we don't risk shrapnel ), so you can't go any higher.
What you can do is add air storage tanks (up to 4 by the rules), and your high pressure won't drop so drastically each time you use it.
You do need to consider managing your air supply and how fast and how often you can use those pistons, including precharging your pneumatics storage just before going on the field to play in a match.
Unread 30-01-2009, 11:21
Electrical Engineer
Rookie Year: 1995
Re: compressor help
No. If you modify the system for more than 120 psi, the inspectors at your event will prevent you from competing. Moreover, it is a safety risk.
To minimize pressure loss, use accumulators to store a larger volume of compressed air. I very strongly suggest that you read the Pneumatics Manual and section 8.3.9 of this years rules before proceeding any further with your development.
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 30-01-2009, 11:51
carbuff's Avatar
carbuff carbuff is offline
AKA: chad parsons
FRC #2228 (cougartech)
Team Role: Scout
carbuff has a spectacular aura aboutcarbuff has a spectacular aura aboutcarbuff has a spectacular aura about
Re: compressor help
yes like others said the compressor is only limited in competion to 120 psi and you will not be able to compete if over 120 psi
help with Compressor and labview Team2883 General Forum 4 28-01-2009 22:18
COMPRESSOR & PRESSURE SWITCH HELP... programmr Programming 8 15-02-2008 12:33
Help with Compressor please, sir! Amisca Electrical 8 19-02-2007 17:04
1482 Help with Compressor Rinaldi 427 General Forum 7 31-01-2007 07:46
Help With Compressor Code fred Programming 6 21-01-2005 17:40
