Go to Post All I can say is - we are such geeks! - Raul [more]
Unread 30-01-2009, 11:43
BLAQmx's Avatar
BLAQmx BLAQmx is offline
Software Engineer
no team (National Instruments)
BLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of light
Re: Proper procedure for deploying Labview code?
I was getting a similar error to Daniel when I lost connection to the cRIO during deployment.
Deploying Sensor Fusion Robot Project.lvproj
Deploying RT CompactRIO Target (successfully deployed target settings)
Deploying Accumulator.lvlib
Deploying MotorControl.lvlib
Deploying Camera.lvlib
Deploying NI_FPGA_Interface.lvlib
Deploying NI_FPGA_Interface.lvlib:NIFPGA SPI.lvlib
Deploying NI_FPGA_Interface.lvlib:NIFPGA Interrupt.lvlib
Deploying NI_FPGA_Interface.lvlib:NIFPGA Global.lvlib
Deploying NI_FPGA_Interface.lvlib:NIFPGA Encoder.lvlib
Deploying NI_FPGA_Interface.lvlib:NIFPGA DMA.lvlib
Deploying NI_FPGA_Interface.lvlib:NIFPGA System.lvlib
Deploying NI_FPGA_Interface.lvlib:NIFPGA Counter.lvlib
Deploying NI_FPGA_Interface.lvlib:NIFPGA CounterEncoderSourceConvertion.lvlib
Deploying PWM.lvlib
Deploying NI_FPGA_Interface.lvlib:NIFPGA Watchdog.lvlib
Deploying AnalogTrigger.lvlib
Deploying NI_FPGA_Interface.lvlib:NIFPGA DIO.lvlib
Deploying DigitalModule.lvlib
Deploying DigitalOutput.lvlib
Deploying NI_FPGA_Interface.lvlib:NIFPGA AI.lvlib
Deploying NI_FPGA_Interface.lvlib:NIFPGA Solenoid.lvlib
Deploying AnalogChannel.lvlib
Deploying Joystick.lvlib
Deploying Ultrasonic.lvlib
Deploying VariantType.lvlib
Deploying DigitalInputFilter.lvlib
Deploying DriverStation.lvlib
Deploying NI_FPGA_Interface.lvlib:NIFPGA AnalogTrigger.lvlib
Deploying AnalogModule.lvlib
Deploying DigitalInput.lvlib
Deploying Servo.lvlib
Deploying Gyro.lvlib
Deploying Counter.lvlib
Deploying Watchdog.lvlib
Deploying RobotDrive.lvlib
Deploying FRC Robot Boot-up Deployment (failed to deploy)
Download completed with errors.
I suspected this was because the power on my battery was low. When I connected a power supply to my cRIO I was able to deploy successfully.
Deploying Acquire Image.vi
Deploying Async VI Agent.vi
Deploying Autonomous Independent.vi
Deploying Robot Main.vi
Deploying Send Images To PC.vi
Is this a possible cause for you issue?
NI FIRST Community: Where to go for LabVIEW, Wind River, cRIO-FRC, and NXT support.
help me in LabView code mahmosh National Instruments LabVIEW and Data Acquisition 3 11-01-2009 00:18
Problem deploying/running default code blaxbb FRC Control System 0 10-01-2009 11:59
pic: Team 58 deploying ramps - www.riotcrew.org for more bobl Extra Discussion 7 27-02-2007 20:09
Can anyone tell me the proper code for line sensors thelastride Programming 1 14-02-2004 13:47
Custom Dashboard code for LabVIEW ready for download. archiver 2001 3 24-06-2002 00:49
